Old 08-25-2014, 07:32 PM   #1
T-r3x
Drives: 2010 camaro ss ( LS3 )
How to replace Magnuson injectors?
Hello guys,
I was wondering if I can replace my injectors in my home. Is an easy process or does it need a professional tech? Please give me a detailed instructions if it's easy to do. Thanks all :-)
T-r3x is offline   Reply With Quote
Old 08-25-2014, 08:41 PM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
Injectors are typically easy to change. IDK how much complexity the supercharger adds though.
However, if you're changing the size (flowrate) of them, you have to be able to re-flash your computer with the new flowrate data.
Jack Bilger
granatl is offline   Reply With Quote
Old 08-25-2014, 09:32 PM   #3
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Originally Posted by T-r3x View Post
Hello guys,
There's 2 10mm bolts that hold the fuel rail down. Remove the fuel line from the front of the rail. Remove the 2 10mm bolts. Lift the fuel rail off the injectors. Swap injectors and put the rail back on. You will need a tune for the new injectors.
Edit: You may have to disconnect the fuel line from the back of the rail to.
Nitroman28 is offline   Reply With Quote
Old 08-28-2014, 11:25 AM   #4
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
30 min job in your own garage (beer time is extra)
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 08-28-2014, 02:31 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Sometimes it's hard to pop the old injectors out of the mani, a wide screwdriver used carefully may help a bit. Careful!
Some lube makes insertion easier (in most aspects of life).
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 08-28-2014, 05:34 PM   #6
fourmz
Fourmz
fourmz's Avatar
Fact.
Old 08-28-2014, 05:36 PM   #7
T-r3x
Do I need to unplug fuel hoses? Cause it looks hard to remove /:
Old 08-29-2014, 03:25 PM   #8
fourmz
Fourmz
fourmz's Avatar
I did disconnect my fuel line but you may be able to get away with out removing them
