10-27-2018, 09:54 PM | #1 |
Trunk Lid Bump Stop
Going to see if this way to post pics works better than uploading directly as an attachment. Would someone please let me know if the pic below appears or not? Thanks.
Do any of the 2015 owners have those trunk lid bump stops in their trunk lids? gmpartsdirect don't show this type of bump stop. When I google searched Trunk Lid Bumper - GM (92231413) a couple images showed up that indicated they're made for a Pontiac G8. Thanks for your time folks. |
10-28-2018, 03:25 AM | #2 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
Yes my 2015 has them, either side of the catch.
10-28-2018, 05:47 AM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
Without actually look into this myself, maybe check a G8 forum; the G8 uses a very similar chassis (Zeta platform as opposed to the Camaro's Zeta 2 platform) so the bumpstops might be the same.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
10-28-2018, 06:30 AM | #4 | |
Drives: 10 2ss/rs Join Date: Jul 2018
Hes talking about the spring loaded bumps on the trunk lid that lift it a lil when you pop it so it doesn't latch again. So in reality idk if they are bump stops or spring assists
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
10-28-2018, 08:24 AM | #5 |
I know, just thought that possibly they're the same between the two cars, but I have no idea.
10-28-2018, 12:13 PM | #6 |
Drives: Camaro V6 Join Date: Oct 2016
All 5th gen Camaro's have them.
10-28-2018, 12:13 PM | #7 |
My 2014 has them too.
It's number 5 on this diagram. EDIT: **Actually I noticed it says convertible, you may want to send them your VIN number to make sure the part is correct.** The part number doesn't show up for the coupe, the parts might be the same but I would check first. https://www.gmpartsdirect.com/oem-pa...Y4LWdhcw%3D%3D |
10-28-2018, 01:03 PM | #8 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
The dam things keep pushing up into my lid. I have replaced them a few times.
10-28-2018, 05:38 PM | #9 | |
That's the same problem I'm having. If it happens again while I'm doing the kindler, gentler trunk lid closing method I will gorilla glue those pistons into the rubber. Thanks to everyone for responding. |
