06-13-2017, 11:50 AM | #85 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
You only need to put the resistor across the circuit once. The rear lights are wired in parallel, so the second resistor is redundant. Having them in parallel with those resistors wont hurt though.
06-13-2017, 01:34 PM | #86 |
Will having the resistors installed cause a power drain? My ZL1 sat for 5 weeks and the battery was dead. I know to have it on a battery tender, but I thought that was still pretty quick on a power drain. I have one resistor installed on each LED, I had a few led's on just using one.
06-13-2017, 02:07 PM | #87 |
Drives: Traded in 2016 BLUE VELVET 2LT RS Join Date: Aug 2016
I have one installed, My car had been parked for 3 weeks last month, and no issues.
06-13-2017, 06:49 PM | #88 |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
No problems with any power leakage on the ones i have installed and 1 resistor per side is all i used.
06-13-2017, 06:54 PM | #89 |
the resistors on the rear lights act as a sink for current that is already leaking because the reverse switch is crap.
Resistors or not, LED lights or not, when the lights are off the same power drain will exist. It's very little so you can get away with a quarter watt resistor. You only need 1 total. It's not a load resistor in the same sense as what you'll see thrown around when referring to things like can-bus led's. The front blinkers are a completely different story. |
06-13-2017, 06:55 PM | #90 |
Good to know, thanks for the replies at the dealer now for its first oil change there checking out for power drains
Sent from my iPhone using Tapatalk Pro |
06-13-2017, 08:07 PM | #91 | |
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6 Join Date: Oct 2015
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package. Ordered 1-28-16: 1100 2-11-2016 :2000 2-15-2016: 3000 TPW of 3/7...That went quick! 2-26-2016: 3400 Status TPW 3/7 3-5-2016 : 3800 3-8-2016 : 4300 3-11-2016 : 4B00 3-15-2016 : 4200 3-22-2016 : 4800 3-29-2016 : 6000! |
04-18-2020, 04:58 PM | #92 |
Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
Thank you! This helped me greatly in disconnecting the front bumper electrical connection. Was stuck on thinking the release of the red tab freed the connection.
