08-18-2023, 08:35 AM | #57 | |
Snackbar Tuning
Not trying to cause any issues here but more define what was posted earlier in this thread is not a problem. King specifically said that someone wasn't able to maintain higher than 50psi on a Camaro SS with this setup. It seems like this was glazed right over and not addressed. We install a ton of DSX low sides but there are quite a few customers that would prefer to not drill the tank. We are interested in the viability of this product to support Heads/Cam/larger injector ZL1's pushing 800-900 rwhp on E60-E80(E80 cars run usually have meth too for cooling) Can you confirm if your product will support a low side pressure/volume required to maintain 70-80+ PSI for these kinds of builds? I didn't see anyone directly ask you and I wanted to know. Thanks |
08-18-2023, 08:50 AM | #58 | |
https://katechengines.com/i-30498248...mp-module.html With 70psi of lowside pressure it should support 1,000rwhp on E60. You can also add a voltage booster (up to 18v) to increase head room if needed. |
08-18-2023, 09:31 AM | #59 | |
Snackbar Tuning
I would think dual pumps require double the amperage so maybe someone who didn't have luck with this system didn't have it wired correctly. Anyhow, thank you for confirming the expected performance. |
08-18-2023, 09:57 AM | #60 | |
Ours has almost double the capacity. If you can make 600RWHP on your dyno using E60 with the factory low side ours would support 1050RWHP with a 20% safety factor built in. Last edited by Katech_Mike; 08-18-2023 at 11:48 AM. |
08-18-2023, 12:30 PM | #61 | |
Drives: 2024 ZL1 M6 Join Date: Sep 2018
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
08-18-2023, 12:53 PM | #62 |
