06-10-2021, 06:25 AM | #29 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Yeah. And the pumps around here state up to 10% ethanol content. Although, it's been as high as 13%, 93 octane. Very, very few places have ethanol free. On a side note, there is now a 15% ethanol, 88 octane, pump at a few locations.
06-10-2021, 07:26 AM | #30 |
I would not run a mix of E85 without the composition sensor, but from what I've read, which is a good bit, the ECM is capable of compensating for about an 80/20 mix. Anything higher, you will be running lean. Ethanol is higher octane so the timing is not such a big deal, but lean AFRs while pushing the engine is good way to make it go boom. You will also make less power without the sensor and tune.
I run E85 on my mud truck which is an 11:1 427. I put the sensor in, ran the wire to the PCM and had my tuner alter the tune, which was no cost. I also put a Walbro 415lph in the tank and that melted one of the stock fuel pump wires because of the amperage it was drawing. The truck seems to run better on corn and you can't beat $2 a gallon race gas, but thinking you can run hard without adjusting the tune is going to end badly at some point. At a minimum you should have an AFR gauge that has a datalogging capability to know where you are at.
06-10-2021, 01:17 PM | #31 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
Quick question. I have a gas station that sells ethanol free 93. Would you guys run that?
06-10-2021, 01:26 PM | #32 |
I wouldn't pay more for it unless the car sets a lot. If it was a vehicle that hibernates during the winter, I would consider filling up with ethanol free before parking. If I remember to, I will do this with my lawnmower and yard equipment at the end of the season.
06-10-2021, 01:28 PM | #33 |
That’s all I try to run. Because of elevation premium out here is 91 but I run it ethanol free. Sometimes you can’t find it if you're in an unfamiliar area but that’s all I buy locally. My car likes it.
ABM #2399 2SS/RS:SOLD
06-10-2021, 04:00 PM | #34 | |
I’m curious bc I’ve never tried it. |
06-10-2021, 06:59 PM | #35 |
Mainly I started using it because there’s times where my car will sit for several weeks/months and I didn’t want to deal with the issues ethanol sitting long term brings. I noticed that after doing the fuse pull it runs and holds the high octane map a lot better than with the ethanol blended premium. I was having to do the fuse pull about every oil change before. Now it stays in the high octane map with out issue. I’ve never run anything but 91/93 in it depending on where I’m at, and what’s available. Never 1 time have I put anything other than premium in it. It seemed like to me the ethanol was messing with the fuel maps. It also seems to get slightly better fuel mileage as well(1-2 mpgs). Fwiw My car sees less than 3K miles per year the last 2 years. Maybe I’m crazy IDK.
06-10-2021, 08:02 PM | #36 | |
I just double checked the gas station near me and they only offer 89 EFREE. With my car having a 93 tune I was just curious about the why. I appreciate your response. |
