03-08-2016, 12:10 PM | #15 |
Drives: 2016 Camaro SS Join Date: Jan 2016
I'm not asking for the data here. I'm asking for the methodology by which they approached the design of their product. It's a fair question. If they choose not to answer it then that is their choice. The stock system sees a 4-5 kPa drop at the top end. That is limiting power by approximately 4-5%. Now that is one single data point taken from inside the intake manifold. Where are the restrictions actually at? Is it the open air side of the filter? Is it the filter? Is it the filter box outlet? Is it the MAF tube? Is it the major bend? Is it the TB? Is it the intake manifold opening? Is it the filter element? How can you possibly "engineer" a solution if you don't fully understand the problem? If these things are being design by dyno results only it is a flawed approach.
I'm prepared to drop $1K on the MSD intake manifold but until I get the before/after MAP data from the dyno runs posted I'm not parting with the money because once it is installed I can't just return it. I suspect there is a bump on the MAP but a little data would go a long way at making the choice easy. |
03-08-2016, 12:22 PM | #16 | ||||
http://www.camaro6.com/forums/showthread.php?t=431586 Quote:
03-08-2016, 12:30 PM | #17 | |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
03-08-2016, 12:38 PM | #18 | |
Drives: 2016 camaro ss Join Date: Oct 2010
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp Last edited by jimmypop13; 03-08-2016 at 12:48 PM. |
03-08-2016, 12:58 PM | #19 |
That's the one I've seen. My launch control screenshot shows the same thing. It is not unexpected. The issue is that you can't infer from that exactly what needs a change to decrease the pressure drop. You have to measure the drops along the entire tract. That means grabbing a differential pressure meter and drilling holes as you go. Without doing this you are only guessing. There may be one major area or there may be a lot of smaller drops that add up. The MSD intake manifold appears to have improved through legitimate air flow improvements. If this is true then the intake manifold is the primary offender not the stock intake tract. How could more air be flowing through the intake manifold if the intake tract is so restrictive? The intake manifold is post MAF so no unintended consequences.
03-08-2016, 01:43 PM | #20 |
Drives: None Join Date: Feb 2016
Roto-Fab CAI for 2016 Camaro SS Sneak Peak!
Well, you can at least narrow it down to CAI, TB, or IM. We already know that an IM and ported TB help, so why not just go ahead and do those things first. Then, you can remeasure your vacuum after that. If the TB and IM show no restriction with the stock CAI, you don't need to spend the money on an aftermarket one.
The other way to see if it helps is by tuning a completely stock car to optimal power. Then, install a CAI and retune it for the MAF changes so that the AFR is correct. Tune it for optimal power with the new part, and see if there are gains before and after. There will be several vendors that will do that kind of testing for the community. Just be patient and don't buy one until you see what you want to see. A CAI isn't going to drastically help an NA car, so what are you really missing by waiting a bit longer? You can use common sense and see that these aftermarket parts have better flow potential than the stock part. The question isn't,"will it flow more?", it's,"will it be of any benefit on a given setup?". That depends on what you have done to the car, or what your plans are down the line. On an otherwise stock car, why worry so much? On a full bolt-on, H/C/I car, I'm sure it would be needed. Vendors can't post all their information because if they're first to market, the competitors are just going to make changes until they figure out how to make a better performing part. Last edited by Nataphen; 03-08-2016 at 01:53 PM. |
03-08-2016, 02:21 PM | #21 |
A quality vendor would make sure they are putting out the best product they can regardless of what anyone else is doing. This isn't rocket science. There is no special sauce. If you are going to spend money on tooling at least put a little data behind your design.
03-08-2016, 02:58 PM | #22 |
And, as I said, there will be vendors that will do just this for you. Obviously, none of the manufacturers want to give out the exact data that you're wanting for whatever reason. Wait for someone else to test it before you buy. I don't know why none of the manufacturers don't want to share this data, but it's apparent that they don't. That's why I don't get into a rush to buy stuff.
03-08-2016, 03:04 PM | #23 |
I'll also add one more thing. I'm not running a part that throws the AFR off without a tune. I don't care who says it's safe, I want my MAF dialed in.
03-08-2016, 05:39 PM | #24 |
So JDP got back to me with their MSD intake MAP data. If you want the specific data request it from them but the stock intake saw approximately a 5% drop in manifold pressure from at 6600 RPMs relative to the pressure at 2000 RPMs. The MSD intake saw only a 3.5% drop in manifold pressure at 6600 RPMs relative to the pressure at 2000 RPMs. They didn't give the baro but the MAP at 2000 RPMs should be pretty close to it so it. Timing and AFR were consistent between the runs.
That bump in manifold pressure may seem small but it is 30% of the total loss recovered and the MAF is not skewed. That is a true airflow increase. The manifold design itself will obviously have an impact on how well the cylinders get filled beyond just MAP gains. So there is about a 3.5 kPa (0.5 PSI) loss still unaccounted for between the entrance to the filter box to the outlet of the throttle body. What is the next largest weak link? I'm betting it is the actual throttle body diameter. A port job isn't going to mitigate a loss there unless it also increases the smallest bore diameter. GM had to pay attention to velocity as well not just max flow for low RPM performance. I'll speculate that a Katech 103mm TB might be a worthy companion to the MSD intake (especially on a larger displacement setup). The issue here though is that on a stock engine it may be too big and you will lose dynamic range on the throttle control. Last edited by TSloper; 03-08-2016 at 07:14 PM. |
03-08-2016, 06:20 PM | #25 | |
Drives: SS 6 speed of course Join Date: Jan 2016
03-08-2016, 07:39 PM | #26 |
Drives: Anything I want Join Date: Oct 2008
03-08-2016, 08:08 PM | #27 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Working with BBK even trying a 90mm TB will hit and a spacer would be required. But one thing to note, the stock GM TB dosen't perfectly align at WoT and is blocking or creating a non smooth flow of air into the intake manifold. Even MSD suffers from this and a wide mouth IM needs to be made to see how this motor/car would respond. I am not sure of any companies looking at this.
03-08-2016, 08:35 PM | #28 | |
