04-03-2021, 08:19 AM | #141 |
Got to head up to Mo-Kan with a buddy last night to get a new baseline and made 5 passes. The first pass was the best with a 11.79 @115.98 with maybe a touch of spin @ 18psi. Dropped to 17.5 on the next pass then .5psi on each of the following passes as well. Spun on every pass after the first one but it did cool off rather quickly. Tried rolling into the throttle but I need more practice with that.
The last pass it felt like the traction control kicked in just before half track, or thats what it felt like anyways. I had the nannies off but not sure what the cause was. Car seems to be fine. Still was a fun night and ready to go again. The tires did rotate a bit on the rims, 3" on the left and 4" on the right. I will add pictures later. I had the same issue with the MRR's and 20" drag radials so I'm not surprised. Right side tire movement Left side tire movement
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP Last edited by Ashen 6.2; 04-03-2021 at 09:12 AM. |
04-03-2021, 08:22 AM | #142 |
Evil Genius of Chevrolet
I assume you heated them up before the runs?
04-03-2021, 08:38 AM | #143 |
Yes! Burnouts/good smoke on all passes. The first one was probably the lightest burnout of the night. Of course I didn't think about that till I was on the way home.
04-03-2021, 08:44 AM | #144 |
You got me thinking I should mark my tires and check for drift too.
04-03-2021, 09:09 AM | #145 |
I would recommend it. I used a silver sharpie to mark the tire with the valve stem location. With the MRR's I just took pictures before and compared later.
04-03-2021, 09:13 AM | #146 |
Added tire pics to post above.
04-16-2021, 08:50 PM | #147 |
Finally got around to getting the MRR’s powder coated black. Really liking this change!
04-17-2021, 08:34 PM | #148 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Looks good
04-18-2021, 05:52 AM | #149 |
04-18-2021, 08:04 AM | #150 |
Drives: 2010 SS L99 Join Date: Sep 2018
Aside from the Welds, are you full weight on track day?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
04-18-2021, 09:00 AM | #151 |
It was for the last trip to the strip 2 weeks ago.
I have since removed the rear seats and replaced with a Shrader Performance rear seat delete kit. Decided to do that when I swapped out the fuel pump & FPCM.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP Last edited by Ashen 6.2; 01-16-2022 at 06:02 AM. |
06-23-2021, 06:38 AM | #152 |
Been doing a lot of stuff over the last few months. Was looking at a LSA setup but started seeing some of those parts going on back order/hard to get. Ended up going with a Maggie Heartbeat, DSX aux pump, ID1050's, GPI SS3 PD cam & GPI ported heads.
So, started by getting the car sideways in the garage and lifted with the quick jacks Last pic of what it looked like before getting started Took the nose off. Then tearing down the engine began. Got the block out Did the oil cooler delete while it was out ICT Cooler bypass installed New coolant plug installed Flex fuel sensor installed White wire goes into pin 40 Shot of the wire loom before pin 40 is in Arrow showing white wire in place
06-23-2021, 06:41 AM | #153 |
Very nice. Those Maggie's put down good power.
06-23-2021, 06:43 AM | #154 |
Next up was getting the DSX aux pump in. No pics while drilling the hole in the tank but several after it was finished.
Pump in place Fitting in tank and hose attached tee installed
