Old 04-20-2015, 05:40 PM   #15
BryceClark89
BryceClark89's Avatar
Drives: 01 Alero GLSV6/ 07 ZX-14/ 06GTO
CTSV yes ATSV no..the point was it took months before any viable information was given about rhe ATSV estimated 60 3.9 estimated top speed 185 about 3700 lbs ..not terribly specific
Owned lifted 88 dakota two door short bed V6 4x4, Yellow/black LB9 powered 85 IrocZ28 MODS Edlebrock intake, throttle body spacers and mass air flow sensor, Edlebrock full exhaust, K&N drop in's, B&M 700r4 shift kit. 2001.olds alero GLSV6, BIKE~ 2007 Lazer Metallic Blue ZX-14
BryceClark89 is offline   Reply With Quote
Old 04-20-2015, 05:43 PM   #16
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Originally Posted by BryceClark89 View Post
...as i said before no performance specs have really been officially announced until just recently ..both of you are uttt wrong. Yes they announced power but it was never official Certified power and tourque figures ...and where donyou see ATSV specs ibsurebas hell dont beside there "estimated" 3.9 -60 ..and about 3700lbs while terribly specific it gives an idea once again not a certified number
ATS-V
http://blog.caranddriver.com/2016-ca...an-gm-thought/
CTS-V
http://media.gm.com/media/us/en/gm/p...222-cts-v.html
You are right if you are referring to timed performance. There's no cars on sale or available for review yet which is why.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 04-20-2015, 07:05 PM   #17
Thebeezwax
Thebeezwax's Avatar
Drives: Has 4 wheels
why do people keep thinking the Camaro will have more power than the Vet?
445hp max
Thebeezwax is offline   Reply With Quote
Old 04-20-2015, 07:11 PM   #18
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
445hp max
More wishful thinking than anything, Some feel the Vette will get a power boost also to keep it above the Camaro.
The Bird is the word!
Old 04-20-2015, 07:21 PM   #19
alcal1084
Drives: 2012 45TH AE SS
445hp max
Why do people keep thinking the Camaro will have less power then the vet?
It's the same engine... It will make the same power. The only piece of info that would make us believe it will have more power is the addition of the new headers. Now having said that if the next Corvette gets the same then it will have a power increase. The guys and gals that are making the new Camaro do not care about the corvette. Their goal is to make the best Camaro that's it.
alcal1084 is offline   Reply With Quote
Old 04-20-2015, 07:25 PM   #20
newb
newb's Avatar
Drives: 2013 1LE
Will they reveal HP and TQ tomorrow?
445hp max
Why would they go through the effort and expense of designing and manufacturing nice exhaust headers to give it less horsepower? The simple common sense test doesn't make sense. If you plan to give it less power you give it the same exhaust manifold currently on the vette and detune it in the ECU. That's a lot cheaper and faster.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 04-20-2015, 07:49 PM   #21
Bhobbs
Bhobbs's Avatar
445hp max
The tri y headers would be absolutely wasted unless they were trying to squeeze more power out of the engine. The headers may be an attempt to keep power up with the longer Camaro exhaust or they might be planning to make more in the Camaro than the Corvette. If they were planning on having the usual difference in power, the Camaro would probably keep the usual and cheaper cast manifolds.
Old 04-20-2015, 10:37 PM   #22
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
450hp min
fixed
ilirg is offline   Reply With Quote
Old 04-21-2015, 12:26 AM   #23
MrChrisLS3
Drives: 2018 1SS M6
Looks to be the very same LT1 in the Vette. I really don't think they'll do anything to change the specs of the engine, as it wouldn't really be cost effective. Of course things like air intake, exhaust piping, and driveline will effect the final output to the wheels.
MrChrisLS3 is offline   Reply With Quote
Old 04-21-2015, 07:46 AM   #24
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
Exactly. If they wanted it to make the same / less then they could've just threw in the LT1 as is and let the difference in intake / exhaust take its toll and decrease the horsepower so it would be under the C7's rating (see LS3 camaro / corvette).
xgnxs is offline   Reply With Quote
Old 04-21-2015, 09:08 AM   #25
SuperSound
SuperSound's Avatar
And that resulted in a difference of 4hp. I'm pretty sure tri-ys will give us more than 4hp.
Old 04-21-2015, 09:15 AM   #26
xgnxs
xgnxs's Avatar
I hope so!
Old 04-21-2015, 12:36 PM   #27
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Funny that 4 hp is pretty close to plus or minus 1% of 430hp. The new sae standards require them to be accurate within 1%. Gm could rate the ls3 from around 425 to 435 hp and be within limits. It's likely the same motor. It will show lower rwhp numbers in the camaro due to slightly greater drivetrain loss. Bigger wheels and some other things.
ULTRAZLS1 is offline   Reply With Quote
Old 04-21-2015, 12:46 PM   #28
IOMike
Drives: 2022 F150, 87 Monte Carlo
The dual mode exhaust is also worth 5hp on the corvette and it will be an option on the gen6. Unless the tri y headers only come with the dual mode exhaust I predict the Camaro hp will be what the c7 numbers are at a minimum. 455 and 460. Possibly 5 more.
IOMike is offline   Reply With Quote
