dave@hennessey
Old 03-27-2012, 07:19 AM   #1
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Dash lights flicker while driving
Ok I have search near and far on this forum and found nothing. I have this issue that when I am driving the dash cluster (speedometer and rpm gauge) flicker but dont turn off. If I hit the brakes they will dim slightly then return to the same brightness right after. I have had the battery replaced by the dealer, they checked the alternator and it was good but even after a new battery was put in it the problem still persists. Note: if I have my footwells on they will do the same thing. Nothing else on the car flickers just the footwells and dash cluster.
c_LoW29 is offline   Reply With Quote
Old 03-27-2012, 08:22 AM   #2
Camaro21
Drives: SOLD - 2013 M6 ZL1
It sounds like you might have a GROUND issue someplace.
Camaro21 is offline   Reply With Quote
Old 03-27-2012, 08:27 AM   #3
c_LoW29
were would you suggest I start? I dont have any aftermarket radio components and the footwells are tapped into the 12v lighter in the fuse box. I have no other electrical work done to my car.
Old 03-29-2012, 12:41 PM   #4
c_LoW29
bump anyone?
Old 03-29-2012, 12:48 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
It's probably a ground issue. If you can I'd take in to a dealer. Finding the source of a false ground can be pretty time consuming as it can be anywhere.
Click to view my build thread
Old 03-29-2012, 12:54 PM   #6
c_LoW29
I Did take it to the dealer they could not reproduce the problem as usual.
Old 03-29-2012, 04:03 PM   #7
The Stig
The Stig's Avatar
Call Chevrolet customer service. Or next time it does it take a video with your phone
Old 04-03-2012, 02:46 PM   #8
babarudy
babarudy's Avatar
Drives: 2010 2lt rs jewell tint
i noticed the same thing, what i figured out , is its the automatic lights going on and off in certain low light conditions.
[url]
babarudy is offline   Reply With Quote
Old 01-05-2016, 12:12 PM   #9
U Can't Z Me
Drives: 2010 Camaro 2SS M6
I'm having the same issue. When I hit the brakes, turn signal, windshield wipers or rear defrost, the dash lights and headlights momentarily dim out and then come back up to normal.
It's definitely a ground issue somewhere.
The dealer tried to tell me that I needed my injectors and IAC cleaned...which is about the dumbest thing I've ever heard.
I've had issues with the seat heaters occasionally not working as well, so I'm going to have to start tracking my grounds.
Anyone know a reliable shop in the Dallas/Fort Worth area that may be able to help?
U Can't Z Me is offline   Reply With Quote
Dash Cuts out while driving tjudah87 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 12-21-2011 06:33 PM
Running fog lights or the daytime driving lights on while the headlights on? BloodThirstyCamaro11 Cosmetics and Lighting Modification Discussions 13 07-13-2011 04:18 PM
Grille driving lights as the DRL on non RS Camaro? torranosaurus Cosmetics and Lighting Modification Discussions 0 04-29-2010 03:34 PM
