09-29-2023, 08:20 PM | #29 | |
09-29-2023, 08:32 PM | #30 |
Same here, and zero drone as well. Even when I run catless for the strip, zero drone then too. Was loud AF before I installed the Magnaflow center muffler though.
09-29-2023, 09:15 PM | #31 | |
09-29-2023, 09:50 PM | #32 | |
Negative, I believe this is the one I had my shop use: https://www.magnaflow.com/products/1...-muffler-12469 I’d suggest that you only let a trusted shop who is good with fabrication do the work. It’s a tight fit that was made worse by my 3.5” aluminum driveshaft. If you’re still running a 2-piece DS it might fit a little easier.
09-29-2023, 10:01 PM | #33 | |
09-29-2023, 10:24 PM | #34 |
09-30-2023, 04:43 AM | #35 | |
https://www.camaro6.com/forums/showthread.php?t=576096 |
09-30-2023, 06:07 AM | #36 | |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Prior to this, I had stock headers -> stock primary cats -> AWE Performance Link Pipes (secondary cat delete) -> AWE resonators-> AWE Touring. TBH, it sounded outstanding as well. Louder and deeper than stock for sure. If you have / choose this option, I don’t think you’ll be disappointed at all. Overall, AWE has been a solid improvement. Keep us updated and good luck!! |
09-30-2023, 10:30 AM | #37 |
Thanks a lot guys for the info and the advice, I ordered the muffler today. We'll see (hear)
10-01-2023, 09:21 PM | #38 |
10-01-2023, 09:33 PM | #39 |
The 8" long dual center muffler that Josh has.
I was a little concerned about the overall length of the 11" version that Sakudog used for his ZL1 1LE, his photos show he has very little room left at the rear end. I hope the 8" variant will make enough of a difference with my SS and the factory NPP exhaust. Oh, and I need to find a decent muffler shop in the area by the time the part arrives, although I may try the body shop at my favorite local dealership, their service department has been fantastic so far.
6th gen, headers, zl1, zl1 1le |
