07-31-2023, 07:56 AM | #29 | |
Drives: 2022 LT1, 1981 320i Join Date: May 2022
Thank you! And good question - I went with 285/40/19. I had to double check because I realized that was not a factory size but according to my math: 285/40/19 = Diameter of 27.98 And my original tire was 245/40/20 = Diameter of 27.72" 285/35/19 = Diameter of 26.85" So basically I tired to get as close as possible to OEM and I thought maybe the added cushion would offset any roughness added by the lowering springs. I still want to double check a few things but when I buy some nice tires I'll probably go with 275/40/R19. |
07-31-2023, 08:39 AM | #30 |
Instagram: Sangstah
wow what a transformation, it went from not a build to full build, nice work!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
02-08-2024, 12:37 PM | #31 | |
Haha it's funny how that tends to happen lol! Appreciate the kind words. Thank you sir! Not too much interesting to report on recently. I think I've done two more oil changes since last time and am working on a little 3D print project to keep my EZ pass, radar detector and dash cam hardwired and hard mounted with one big design constraint - nothing attached to the windshield. The reason being mainly so I can easily put up a sun visor when I'm parked at work in the summer. Bonus points because it makes swapping the windshield easier, although hopefully that shouldn't be a regular occurrence. Anyway a picture is worth a thousand words, sometimes more if you're bad at writing. |
02-08-2024, 12:41 PM | #32 |
02-13-2024, 07:39 PM | #33 |
Drives: 2001 Camaro Join Date: Jan 2018
Good new stuff for that nice ride.
