10-02-2020, 03:20 PM | #29 | |
Hot Camaro
10-04-2020, 09:14 PM | #30 | |
Drives: 2016 camaro SS Join Date: Jun 2020
So This will be more BMW and a bit less LT1
Check out my latest video here! But still I will have a lot of LT1 questions. Especially about fitment and aftermarket parts. If you all are not sure you want to see more of this swap since it's more BMW and less LT1, let me know. I'll understand. But I will tell you this - and it's MORE LT1 related than anything!
I'd like to know what the others do given these setbacks. I wonder if the T56 is better suited for this application? There were some other things I noticed with regards to the transmission.
Other than that, Some interferences to be expected. Seems to fit pretty well. I will need to redesign the entire front subframe, relocate the steering system to a rack-pinion to be in FRONT of the axle (as opposed to the originally rear mounted drag link box system). So new spindles will need to be fabricated, which will be wild! Enjoy the pictures! Here's the E24 635csi - 1985 M30 has already been removed, so this makes things a bit easier. Some issues on the E24 as you see below: Now let's take out the LT1: Got the LT1 out and ready to throw in! Got it in, not from above actually - got from underneath, but next time I do this I'm using the lift. I got some interferences. Overall, it has potential to fit quite nicely! It's currently being suspended by jack stands. A lot of fabrication work will need to happen to the front subframe and the steering rack.
Frank Macaluso -http://www.garageaholic.build - BMW Engine Swaps - 607-953-9587 - contact@garageaholic.build
Current Swap 2016 LT1/6 into E24 6er Have an idea? Want to swap an engine? Try me! Contact@garageaholic.build |
10-24-2020, 08:23 PM | #31 | |
Some more work done! So I moved the E24 to the lift and decided to retry test fitting the LT1 in there. So I removed the wiring harness, front accessories, and also removed items from the E24 including hydroboost, ABS, and power steering reservoir such that I can install the LT1 from underneath and observe what my serious interferences are. And in this case, it appears that I do have interferences, but primarily from the transmission (TR6060). it's a wide casing back there! A couple pictures of where I'm at and my latest video of progress.
10-25-2020, 01:31 AM | #32 |
Drives: 17 1SS Join Date: Mar 2017
Nice. If this works I will have to find an e24.....
10-25-2020, 04:32 AM | #33 |
Drives: 2019 ZL1 A10 Join Date: Aug 2018
This is a great build!
10-25-2020, 08:39 AM | #34 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
This beginning to give me flash-backs to my LS/Blazer swap.
10-25-2020, 03:06 PM | #35 |
Drives: 2019 2SS 1LE Join Date: Mar 2020
Awesome build! Something quite interesting I look forward too
And to those saying the 6 series is a collectors car, go collect stamps or something, cars are meant to be driven and the customer who requested this clearly wants to drive his car
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire" Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros) |
10-25-2020, 06:14 PM | #36 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Wow quite a big project. Nice videos and pics.
09-06-2022, 03:38 PM | #37 |
Bringing back an old thread so maybe OP can talk about this build. It looks like he kept moving along.
https://m.youtube.com/watch?v=vj--XLV-qF0
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
09-06-2022, 08:11 PM | #38 | |
Shadow Gray '19 ZLE M6
Kinda glad I'm seeing it now after all the videos are published. Welp, my night is decided. See you all after Part 31
