11-04-2021, 11:10 PM | #1 |
Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Just bought a camaro first time mods
Hey everyone I just bought a 2012 camaro 2ss 45th anniversary edition. It already has a straight pipe and k&n intake when i bought it. I need some first time mods to give me some more power. I am always on this fourm and I know you guys have really good advice. Thank you (Btw its a 6 speed manual with LS3)
11-04-2021, 11:43 PM | #2 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Congrats on your purchase and welcome. There are MANY people here that can give you great advice on getting that beautiful Gen 5 rollin with more horses. I just like crusin with my girl and trying to keep swirls and scratches off the car. So, if i can give you any advice, because it's a 45th edition, keep her lookin good(that shouldn't be too hard).
11-05-2021, 04:55 AM | #3 |
Congrats & welcome!
11-05-2021, 08:18 AM | #4 |
First steps are intake headers tune. Not sure how the K&N's work I sold the one that came with my car and bout a CAI intake much better for cold air. speed engineering headers work pretty well for cheap money, I do recommend getting them coated. Jannetty charged me $300 to have them coated inside and out.
3.91 gears make a big performance difference. lower control arms and trailing arms are good when you start getting wheel hop. Cradle bushings if you still have hop after the arms. Beyond that you will start looking at a cam, or FI or both. Heads flow amazingly well on these so that is far down on the list of mods.
11-05-2021, 08:46 AM | #5 |
Fast Cars and Old Guitars
Another Christmas the kids will go without while dad’s Camaro gets the goodies! Congrats. T’is a healthy addiction. Well, sorta.
11-05-2021, 09:43 AM | #6 |
Drives: 2012 Camaro SS Join Date: Jun 2019
Welcome and congrats! I'd recommend the long tube headers and a tune as a starting point. Also, the LTs make the car sound so good, after doing them I wish I had done them the day I bought the car. The trailing arms, toe rods and cradle bushings (solid or inserts) are also good because they help eliminate wheel hop. None of those are that expensive or hard to install either.
After that, if you've been browsing the forums, you know the sky's the limit!
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
11-05-2021, 10:00 AM | #7 |
As said, headers for sure. Tunes are less necessary for M6 cars, but you would pick up a few hp.
What are you going to use it for, drag racing, auto cross, road course? Depending on the miles it might need some suspension upgrades. It will definitely benefit from 1LE sway bars and radius arm inserts. AmericanMuscle had the Whiteline inserts for $20 about a week ago. Factory bars are cheap if you can still get them. If it has a lot of miles, it might be a good time for new shocks. Some might say cam, but if you think you will end up going forced induction, I would wait until you do that to choose a cam. Not many guys still running nitrous, but that is a quick way to knock a second or more off your ET. Then there are tires...
11-05-2021, 10:41 AM | #8 |
Awesome sir!! Welcome to the family of FINE Camaro folks!! The first thing you are gonna want to do is plant 2 money trees, one for you and one for your girlfriend/wife!! Lots of cool mods you can do with these Camaro's. For performance as mentioned, LT's and a tune will get you going in the right direction. Then depending on what the car is going to be mostly used for, the sky is the limit!! Enjoy that awesome Camaro...
11-05-2021, 11:06 AM | #9 |
Like everyone has said: Intake, Exhaust, Headers, & Tune.
Those tend to be the default "go-to" things that everyone does and benefits the car in all cases. Mine also came with a K&N Blackhawk intake and it works alright, but I'm looking at switching out to a CAI one. Long tube headers wake up the LS and are pretty much a "must do". You will need a tune to get the most from them and especially if you delete the cats. If you want more volume, get yourself a cat-back exhaust system. Plenty out there! Another simple and cheap mod would be a oil catch can.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
11-05-2021, 11:06 AM | #10 | |
11-05-2021, 11:29 AM | #11 |
And Gas
ABM #2399 2SS/RS:SOLD
11-05-2021, 11:37 AM | #12 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Definitely LT headers are a must, 40-50 HP can be gained with a dyno tune. I gained 216 HP with the mods listed below. I don't care for am changes because the car never drives the same.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
11-06-2021, 08:24 PM | #13 |
Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
Get LT's, CAI, high rise intake manifold, a huge TB, ported or racing heads and a fatass cam paired with gears and suspension work and put down mid 500's on a NA build
11-07-2021, 01:06 AM | #14 |
I agree with most others have said. Long tubes, cold air intake (I use Cold Air Inductions), and a dyno tune for the most power you can get. And then if you are not satisfied with the power increase go to a cam next. But I definitely like the way long tubes and a tune feel.
mods |
