dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 05-07-2021, 06:22 PM   #1
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
ZL1 AUX Trans Cooler
Anyone here that has 13-15 M6 ZL1. Can you take a picture of the front lower radiator? Looking to see if the M6 cars have the aux trans cooler. GM says its only the auto cars that have the aux trans cooler.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 05-07-2021, 08:31 PM   #2
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
I believe that only the auto ZL1 has the aux cooler
cdb95z28 is offline   Reply With Quote
Old 05-18-2021, 01:49 PM   #3
Stealth 2010 2SS/RS
Just looking for a picture of a manual ZL1 car to confirm.
2010 LS3 2SS/RS M6
Old 05-18-2021, 08:32 PM   #4
cdb95z28
cdb95z28's Avatar
I'll check out my service manual.
Old 05-23-2021, 03:47 PM   #5
Stealth 2010 2SS/RS
Let me know what you find out.
2010 LS3 2SS/RS M6
Old 05-29-2021, 04:36 PM   #6
cdb95z28
cdb95z28's Avatar
I didn't forget about ya!
I looked in my 2014 Camaro service manual, here are some pics that show the aux cooler.
This pic shows the actual cooler. The service manual doesn't say if it is used with either trans.
The next two pics show the the service manual calling out the LSA Camaro (ZL1) trans cooler lines. Notice they only go into the radiator which is similar to the Z/28 and SS.
This picture shows something I found while researching the ZL1 Aux cooler myself a few months ago. It shows the 6 speed trans with an obvious aux transmission fluid cooler.
So with all that info above, I cannot say for sure that only the auto ZL1 comes with an aux cooler that is mounted in front of the radiator. I guess you still need to lay eyes on a ZL1 with the 6 speed manual.
Old 05-29-2021, 04:37 PM   #7
cdb95z28
cdb95z28's Avatar
Sorry the pics are turned, damn iphone!
Old 05-31-2021, 08:24 AM   #8
Stealth 2010 2SS/RS
I have all the pipes that GM says a maual car need so when they get here i guess we will see. Thanks for the pictures, the first set of pictures look as if its the auto trans.
2010 LS3 2SS/RS M6
Old 07-23-2021, 08:40 PM   #9
NZZL1
NZZL1's Avatar
Drives: 2013 BRM ZL1 Camaro M6
Yes, they do.
I have just replaced my clutch and don't have any good photos, but I used glove finger tips and rubber bands to reduce the mess, as in this other member's post https://www.camaro5.com/forums/showthread.php?t=400884
NZZL1 is offline   Reply With Quote
Old 07-25-2021, 05:14 PM   #10
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
I think I can solve your question. The lines and cooler you are seeing goes to the rear axle to cool the fluid in it, not your transmission. All ZL1's have this and the transmission being a auto or a stick it does not matter. GM did this because the ZL1 really was designed for track use and the rear axle fluid was getting hot
Bigtime53 is offline   Reply With Quote
Old 07-25-2021, 09:31 PM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
That is not correct.. the M6 does have the same coolant pass through and the line continues to the rear end then returns to the front cooler.
ZMEnow is offline   Reply With Quote
Old 08-13-2021, 07:06 AM   #12
Stealth 2010 2SS/RS
I know it cools the rear diff, I have a ZL1 rear diff in my car and looking to complete the cooling lines. I was more interested in part numbers for the coolers or lines that go from the radiator to the AUX cooler.
2010 LS3 2SS/RS M6
Old 08-13-2021, 08:14 AM   #13
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
You just said it a different way but it still cools the rear axle fluid.
Old 08-13-2021, 09:17 PM   #14
ZMEnow
The original question was does the ZL1 M6 have a trans cooler and the answer is yes.
