Roto-Fab
Old 04-26-2021, 11:22 AM   #1
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Cutout Switch Location
A couple years ago I put cutouts on and installed the switch just to the left of the shifter on the angled part of the console. Fast forward to today and I don't really like that location. I am thinking about moving it, yes I will have a hole but I found the new part online for about $100 so swapping it out wouldn't be an issue.
My question is, where do you guys have your switches mounted? Any pictures? I remember seeing a pic where someone had taken out the cigarette lighter and put a switch under that door, which I really like but have no idea what switch they used.
Talladega is offline   Reply With Quote
Old 04-26-2021, 02:01 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I don't have any pictures, but here is where I mounted mine:
At the end of the dash panel, Driver's Side, there is a fuse panel access cover. Remove that, and you will see a flat portion of the lower dash panel, parallel with the floor. I drilled a hole and mounted my switch there. It was easily accessible, hidden from view, and convenient to a switched power source.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 04-26-2021, 07:14 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I installed my switch INSIDE of my console under the lift open cover on the back side/inside where the 12v power outlet is and used the 12v power source that is right there in the console. Really outta sight. lol.
Old 04-27-2021, 12:59 PM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Mine is remote, programmed to the garage door opener.
Old 04-27-2021, 01:00 PM   #5
Vegas Bound
That's where I put my line lock plug.
Old 04-27-2021, 05:02 PM   #6
Rob3D
Rob3D's Avatar
Drives: Car
Old 04-27-2021, 10:20 PM   #7
Talladega
Talladega's Avatar
Originally Posted by Rob3D View Post
What switch is that? Where did you get it?
Old 04-28-2021, 12:54 AM   #8
GetSmart
GetSmart's Avatar
Drives: 2013 Black SS
mine is under the driver's seat
Rotofab CAI, VMAX PTB, Borla S axle-back, Dynatech SuperMaxx 1 7/8" headers/HF cats, No weeds exhaust diverters, Apex air scoop & catch can, Rohana wheels, MPD1 Z-Force Hood, BTR Stage 3 cam, Vitesse Throttle Controller, etc...
GetSmart is offline   Reply With Quote
Old 04-28-2021, 04:46 PM   #9
Rob3D
Rob3D's Avatar
Drives: Car
It’s the NOWEEDS switch...push and forget left and right, center to set how much you want them to open.
Old 04-29-2021, 06:53 AM   #10
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
It is a luxurious style
That would solve my dilemma.
Can you describe how you did it?
George-CZ is offline   Reply With Quote
Old 04-29-2021, 07:02 AM   #11
Umbriel
Drives: 2016 Camaro SS
I bought cut outs that had a remote so I didn't have to have a switch. I'm sure it can be programmed to one of the cars home link buttons on whatever it's called.
Sent from my SM-N986U using Tapatalk
Umbriel is offline   Reply With Quote
Old 05-29-2021, 01:02 AM   #12
satxrider
Bad 45th
satxrider's Avatar
Drives: 2012 45th Anniversay Edition SS
put mine under the flip up 12v outlet on the center console, to the right of the shifter. No holes had to be drilled and its hidden under that outlet cover.
- Carl
2012 45th Anniversary SS - LS3
Magnuson TVS 2300 Supercharger / Alky Meth Injection / Lingenfelter GT12 Cam / Kooks LT Headers, 3 inch exhaust & QTP electric cut outs / Monster LT1-S Twin Disc Clutch / MGW flat blade short throw shifter / Haltech CAI / VMax Throttle Body / DSS Stage 3 axles/ BMR Trailing Arms, Toe Rods, Suspension Bushing and 1" lowering springs / Taylor 8MM Plug Wires / Tuned by Henderson Performance Technologies / EBC dimpled and sloted rotors / G2 Painted Calipers / GM Tower Strut Brace / ZL1 Factory Rep Wheels
satxrider is offline   Reply With Quote
