Old 02-04-2020, 06:48 PM   #1
00Form
Drives: 2017 Camaro SS
Kooks exhaust install - Any advice on slip fit joints
Started this last night and it was harder than I expected. Working on the header connection pipes and the middle portion of the exhaust.
Any advice on attaching the slip fit joints? How far do the pipes need to go. I assume I can use a mallet to work it in.
Thanks
00Form is offline   Reply With Quote
Old 02-04-2020, 07:06 PM   #2
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Thanks
Have you already got to stock stuff off? Make sure you are not hanging up the stock exhaust where the slip fit joint is on the heat shield for the transmission. I spent hours trying to get my exhaust off until I realized it was stuck on.
cmitchell17 is offline   Reply With Quote
Old 02-04-2020, 08:43 PM   #3
00Form
All the stock exhaust is off and I already installed the headers.
On the cats there are some graphics from kooks. Should they be facing the ground?
