Vararam
Old 09-20-2019, 06:30 AM   #1
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
Proform Valve Covers
Anyone have these? I'm constantly getting oil seeping through the oil cap. I bought a new cap and a few days later same thing.
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
KTMracing09 is offline   Reply With Quote
Old 09-20-2019, 04:56 PM   #2
Arch-City
Drives: 2015 Camaro 1LE
Same issue with the GPI branded valve covers, which are made by Proform i believe. Proform's QC must be really lacking, because I have huge burrs inside and outside of the hole. The valve covers seem thick enough where they could have just threaded the hole and problem solved. I have replaced my cap twice and it still leaks right down on the headers. I am going to try and weld a spin cap on them, but the location of the filler hole is so close to the corner radius its going to be a pain in the axx.
Arch-City is offline   Reply With Quote
Old 09-20-2019, 05:54 PM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
My stock covers work fine ,what made you change the stock covers ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-20-2019, 06:01 PM   #4
Arch-City
I run a solid roller and needed taller covers for the adjustable rockers.
Old 09-23-2019, 05:47 PM   #5
KTMracing09
I run roller rockers and needed the clearance as well
Old 09-24-2019, 09:02 AM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
You guys could always switch to the tall Holley valve covers
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 09-25-2019, 06:57 PM   #7
Arch-City
Yeah, I think everyone know they could switch to another valve cover and probably will have to. I just think he was wanting to know if it was a common issue with these valve covers.
But, I must admit that it does suck when you buy a new item that should seal and function like a valve cover should, only to find out right away that they don't and you need to fix them yourself or replace.
Not a huge deal because the cost is not much to replace them. Just hope other see this and are not surprised if they run in to this issue.
Old 09-25-2019, 07:36 PM   #8
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
I use these --->> https://www.texas-speed.com/p-884-um...r-spacers.aspx
No leaks of any kind with stock valve covers.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 09-26-2019, 12:38 PM   #9
KTMracing09
I'm just gonna thread the hole as Arch mentioned and put a screw in cap on it
