08-25-2018, 08:11 AM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
2011 Strut rower brace on 2010 Camaro
So I bought the 2011 Strut tower brace and I need to implant it into the 2010 bodywork.
There is an installation kit, but I can not find it anywhere. Does anyone have this experience please? George. |
08-25-2018, 08:31 AM | #2 |
Drives: 2011 Synergy Green 2SS/RS Join Date: Jun 2014
You need to buy the strut tower brace bracket kit from
TPIS |
08-25-2018, 08:49 AM | #3 | |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
TPIS Kit
Go on the internet you'll find it,Good Luck! |
08-25-2018, 09:49 AM | #4 |
08-26-2018, 09:27 AM | #5 |
Please keep me posted on this . I would love to do this on mine as well but nervous about installing.please post some pics and let me know if this is a PIA to install or not
08-27-2018, 04:47 AM | #6 |
I'll surely put a lot of photos from the installation.
Many people have already done this installation. So I do not see the reason for the potential problem. But it will take a while. The consignment travels over the sea. |
08-27-2018, 08:50 PM | #7 |
Drives: 10 2ss/rs Join Date: Jul 2018
Tpis used to b tuned port injection specialties
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
08-28-2018, 04:49 PM | #8 |
Drives: 2010 2LT/RS Join Date: Mar 2015
Did mine several months back. Turned out great! Pic below is from the time of installation. However, the only thing I would advise at this point is to get rounded hex stainless steel bolts and go from the underside of the strut towers and put the lock nuts on top in the engine bay. Reason behind this - it will give more clearance for your springs. I had an issue with the bolts rubbing against my stock springs. It will also become problematic if you lower the car in the future. TPIS sells a different bolt kit for those who wish to provide more clearance for their springs. Otherwise they stick out like a sore thumb on the underside and need to be cut with a dremel.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
08-30-2018, 10:12 AM | #9 | |
This kit not included stainless steel screws? I will not a lower car. Maximum stiffer stabilizers. Please... link the second install kit. I will look at it. Last edited by George-CZ; 08-31-2018 at 01:43 PM. |
08-31-2018, 01:21 PM | #10 |
Drives: 2015 Camaro Join Date: Aug 2018
Does anyone here have the brace that goes under the car too? I think Spohn company makes it, but there may be other people too.
I'm thinking that if you had that along with the strut bar, it would really stiffen up the front of the car. |
08-31-2018, 04:17 PM | #11 | |
I don't have a link for the substitute rounded hex bolts since it is not online. However, here is the pic below of the kit as you saw on their page. It is the same bolts used in the pics that I used after. It is different than the later version of the bolts that you saw in my first uploaded pic of my strut tower brace. However if you call TPIS, and ask for Jakson Stevens. He is the one who assisted me in getting these other bolts. They cost me $25 shipped. I still had to cut the bolts down with a dremel so that it would not go through the hood of my car. I plan to paint them black to give them a nice contrast under the hood. 1st Pic - TPIS Bolts 2nd Pic - Old bolts underside 3rd Pic - New Bolts underside 4th Pic- RH side top 5th Pic - LH side top
2010 2LT/RS
09-01-2018, 05:57 AM | #12 | |
I would not paint top screws. I would use an black plastic screws covers. I see that the gas piston grip must also be moved. What did you do with the original sheet? Cut off? You have it processed in very high quality |
09-02-2018, 01:35 PM | #13 |
Good idea. Where can I find these plastic screw covers?
2010 2LT/RS
09-02-2018, 02:51 PM | #14 | |
https://www.ebay.com/itm/COVER-CAPS-...r=420746922920 |
