Old 10-13-2025, 10:21 AM   #1
Zachapapa
Drives: 2016 Camaro ss manual
Need help
What year models can I take the diff and Trans from for a 2016 Camaro ss manaual
Zachapapa is offline   Reply With Quote
Old 10-13-2025, 09:34 PM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
They are 3.73 gears for the SS but some have electric limited slip and some have coolant pipes. Some have neither and some have both. So you need to figure out which RPO codes you have to determine whats supposed to be there. Im sure either could be modified to fit also.
bishopts is offline   Reply With Quote
Old 10-13-2025, 09:50 PM   #3
bishopts
bishopts's Avatar
MM6 TRANSMISSION-MAN 6 SPD, TREMEC, 85MM, 2.66 1ST, 0.50 6TH, O/D
G80 AXLE POSITRACTION-LIMITED SLIP
G96 AXLE POSITRACTION-LIMITED SLIP, ELECTRONIC
GT4 AXLE REAR-3.73 RATIO
GW6 AXLE REAR-3.27 RATIO
HRD AXLE REAR-2.85 RATIO
HRE AXLE REAR-2.77 RATIO
KNR COOLING SYSTEM-AXLE
Look at your RPO code list and see which of these you have. You might have multiple.
The big question is "what are you doing?" Did yours break? Did you buy a shell and your piecing it back together? Do you have a car you're converting from a 4cy to a 8cyl?
