08-10-2022, 09:42 PM | #1 |
Drives: 11 Camaro 2SS/RS Blue Metallic Join Date: Jun 2020
I want a 19” wheel set up..will it work
Hope I don’t offend anybody but I never liked 20in rims on a muscle car. I always felt a higher sidewall tire gives it a more aggressive look. With that being said an 18” wheel is too small for our cars so I was thinking of going with a 19x9.5 with 275-45-19 on all for corners! Anybody have that set up and pics or suggestions. Thanks guys
08-11-2022, 07:33 AM | #2 |
Drives: 02 Camaro B4C Join Date: Nov 2016
Yes 19's will work. The Z28 came out with 19's. Just check the tire height between the stock tires and the size you want to go to. If they are the same height you won't need to change the tune in the computer.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
01-16-2023, 11:12 PM | #3 |
Drives: 2k11 5th Gen Camaro 2SS RS Join Date: Jan 2022
I’m looking for the Z28 wheels to put on my 2011 2SS are there any mods needed to get them to fit, I read there’s a bit of a poke from the fenders
01-17-2023, 08:05 AM | #4 | |
01-17-2023, 09:10 AM | #5 |
GPI Sales Consultant
My buddy Max runs a 19x10.5 square setup that looks incredible. I'll see if I can find a picture.
Got a question about a GPI product? Feel free to shoot me a message! |
01-17-2023, 07:04 PM | #6 | |
https://www.camaro5.com/forums/showthread.php?t=611998
01-18-2023, 06:24 AM | #7 | |
01-19-2023, 08:52 AM | #8 |
Totally agree, that is one awesome looking Camaro with those wheels!! Just looks right.
01-25-2023, 11:12 AM | #9 |
Drives: Velvet Blue Metallic 2015 1SS 1LE Join Date: Apr 2018
No shame in that. Most of the time 19's are going to be lighter than 20's, and removing unsprung weight helps with pretty much every aspect of performance and ride quality.
I'm running 19 in. Apex ARC-8's for my summer set. 10's in front and 11's in back. 295/35/19's all the way around. |
01-25-2023, 12:04 PM | #10 |
2019 ZLE Rims
I have a set of 19x11 an 19x12 from a ZLE with 305’s/325’s.
Orange Krush II
01-25-2023, 12:08 PM | #11 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
19 inch wheels were standard equipment for the V6 Camaros without the RS package, so you can definitely make them work.
01-26-2023, 02:37 AM | #12 |
Drives: 2010 Camaro SS manual Join Date: Feb 2022
Do you mean 18" wheel would look too small? I have 18" rims on my SS and I the tires have lot of sidewall, i like the look.
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual. 1978 Blazer offroader with LS1, 1-ton axles. |
Thread Tools | |
