02-24-2022, 02:22 PM | #1 |
Drives: 2019 ZL1 Join Date: Feb 2022
anyone runnning rb ceramic rotors
just checking to see if anyone is running these rotors on their cars ive just started doing road course racing and my biggest issue right now is brakes and im thinking of just going all out and gets these
https://racingbrake.com/gm-crk-05/ |
02-25-2022, 06:50 AM | #2 | |
Drives: Camaro 1ss Join Date: Nov 2019
Have you changed out your factory brake fluid?
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
02-25-2022, 08:08 AM | #3 |
I'm not knocking Racing Brake products, I used their pads on a Z28 with the factory CC rotors. They were very grabby and I had to completely relearn driving the car in corner entry.
I track my ZL1, with upgraded brake fluid, stock rotors and pads, and have had no issues with the setup. The pads do wear a little faster than some aftermarket pads, but for $12k you can buy a whole bunch of replacement pads and tires. If you start tracking your car often, you will realize how expensive and quickly you need tires. Unless you are sponsored and being paid to drive I would really think hard about where to spend the money on track days. On the other hand, maybe you have unlimited funds, in that case go for it and let me know how much you want for the OEM parts. Happy tracking! |
02-25-2022, 07:33 PM | #4 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
It would be a waste of $12k. Until you are in the 2:2x's at Sebring, or the 2:1x's at Daytona, you won't need more brake. The ZL1 and 1LE brakes are amazing when prep'd properly.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
02-27-2022, 05:15 PM | #5 |
Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2021
$12k! good thing i was sitting down.
just wondering, how long would these last!? not that i would drop 12k on these |
02-27-2022, 06:00 PM | #6 | |
On the road, they would be a 'lifetime' part. On track, they wear at roughly the same rate as iron rotors. The big benefit is no fade and lower unsprung weight.
2017 HBM SS 1LE
03-14-2022, 12:02 PM | #7 |
the big issue i have is brakes overheating. i boiled the stock fluid and i figured out i did that cause i was way too aggressive with the car and i still had traction control on and thats what heated up the brakes. so naturally i changed out the fluid to motul 660 but everywhere i see carbon cermaic is basically the best of the best. funds are not too much of an issue cause i would mostly consider it an investment into the car instead of constantly changing rotors and pads so often. i mean if 2 rotors cost $1000 and i have to change more then 2 a year then i would just prefer to spend the money in the right place.
03-14-2022, 12:11 PM | #8 | |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
If you want to get ceramics go for it, but that wasn't what was causing your fluid to boil. I can't speak to the cost of owning ceramic vs Iron rotors but maybe do some research to see which ones would be less expensive for you. I am not sure that ceramic would be cheaper in the long run though. |
03-17-2022, 06:46 AM | #9 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Thread Tools | |
