10-06-2021, 02:55 PM | #1 |
Drives: 2012 SS/RS Vert & 2017COPO#23 SC350 Join Date: Apr 2012
Steering Wheel Wobble after BMR trailing arms
I've had a 100% stock suspension and original wheels with the stock style tires in my 2012 Camaro SS Convertible since it was new (currently have 23,000 miles). After setting up for a drag setup I am experiencing steering wobble that I cannot track down the cause.
I recently installed BMR rear trailing arms with spherical bearings (TCA027) along with the trailing arm outer bushing kit (BK006), I then put on a new set of wheels and tires, the wheels were weld RTS S71 17" wheels. In the rear I had 9.5" wheels with Mickey Thompson ET Street R 28x12.5R17 (P305/45R17). In the front I had 5" wheels with Mickey Thompson Sportsman S/R 28x6.00R17LT After installing the trailing arm, bushings and the new wheels I was experiencing a wheel wobble starting around 40-45mph and worst at 60mph. I just assumed the front skinnies weren't properly balanced. I had them on the car for a 10 mile trip to and from the track and for about 6 1/8th mile passes. Afterwards I took the drag wheels off and put the stock wheels and tire back on I am now still experiencing a slight wobble in the steering wheel starting around 50mph and worst around 60. I never had a wobble before, and while it is less of a wobble with the stock wheels compared to the drag setup it is definitely still there. Does anyone have suggestions of what to check? I cant think of any reason that the trailing arms and it's bushing would lead to a wobble in the steering wheel, but nothing else has changed on the car (other then deleting the cats) since before this started. On my COPO I was experiencing a little wobble in the steering wheel on the shutdown and fixed that by replacing the rubber bushings in the front with solid, but I don't think that should be the cause in my 2012 as it never had the wobble before. Any advice of what I should be checking would be appreciated.
2012 IOM Camaro Convertible 2SS/RS, A6/L99, ARH Longtube headers, high flow cats, x-pipe & mufflers
CAI Cold Air Intake, Kaltech Tuned 2017 COPO #23 Black w/ Supercharged LSX350 2014 Raptor 6.2L Tuxedo Black Metallic w/ 2.9L Whipple, 78Lb/hr fuel injectors, Ford Racing Dual 65mm cobrajet throttle body, kooks headers & exhaust. 1969 Camaro SS (original SS350), Black w/ white Rally Stripes, new ZZ502ci 502hp motor, muncie 4 speed, 4.11 rear |
10-06-2021, 03:43 PM | #2 |
I would start with a wheel balance and alignment. I know you went back to your original wheels/tires, but I would still check balance.
10-06-2021, 04:32 PM | #3 |
Drives: T Join Date: Mar 2015
sounds like wheel weight for one of the corners could have flew off, happens.
10-06-2021, 07:10 PM | #4 |
Alignments seem to affect these cars in many ways including vibrations
Thread Tools | |
