Old 02-24-2020, 03:43 AM   #1
tartarus97
Drives: Audi TT
Hello Driver
The Best Pressure Washer’s Buying Guide
Are you looking for the best pressure washer for cleaning tasks?
If so, please let me know your demands. I will show you how to find a suitable model. Now, let's start to answer some questions below:
Are you interested in using a gas or electric machine?
Do you need to handle a lot of outdoor cleaning tasks quickly?
✜✜✜ Find More Info: Unlock the Power: The Best Pressure Washers Reviewed
Light-duty
Usually, the light-duty pressure washers rate 1300-1900 PSI at 2 GPM. Therefore, they work well for small projects such as patio furniture, vehicles, grills, small decks, and patios.
Medium-duty
I recommend medium-duty pressure washers, which generates 2000-2800 PSI at 2-3 GPM for home and shop use.
Why?
These machines are sturdy and powerful, resulting in high performance. You can clean everything from exterior siding, fences, driveways, and walkways easily.
Heavy-duty and extra-heavy-duty
These machines generate 2800 PSI at a high level of 3-4 GPM; moreover, commercial-grade pressure washers start at 3100 PSI. Thus, these durable machines allow you to fulfill several large-scale cleaning projects such as washing a two-story home, paint stripping, and graffiti removal.
Cold and hot-water pressure washers
If you are looking for a pressure washer for common DIY uses like getting rid of the buildup of dirt, mildew, and loose paint, and cleaning cars, you should consider a cold-water pressure washer.
Meanwhile, it's ideal to use a hot-water pressure washer for industrial and farm use. Although you need to spend more money and more effort on your end for operation, it works better and quicker than the cold-water machines. What's more, this model doesn't require a lot of detergent and cleaning chemicals.
✮✮✮ Picked For You: Who makes the best pressure washer
Types of pressure washers
1. Electric machine
What are the outstanding features of an electric pressure washer?
They are lightweight, cheap ad quick to run. They are less mobile and less powerful than a gas machine, so I recommend them for light and medium-duty projects such as cleaning decks, siding, vehicles, grills, and patio furniture grills.
2. Gas machine
Gas powered washers offer a better level of mobility and power. Therefore, you can use them to deal with large projects such as cleaning exterior siding, sidewalks, patios, and decks.
If you don't like the manual pull-start of a traditional gas pressure washer, you can pick up a push-button electric starter of the Best pressure washer brands nowadays. For the best outcome, try to follow the fuel requirements from the manufacturer.
Tools and accessories
For better and faster performance, you can invest in a few tools and accessories, which must be compatible with your pressure washers:
- Brushes take responsibility for applying scrubbing power.
- Spray tips and extension wands are useful for cleaning hard-to-reach positions as well as two-story homes.
- The combination of angled wands with extensions allows you to clean your gutters thoroughly.
- To clean sidewalks and driveways, you should use surface cleaners and spinning jets.
- No matter what cleaning task you perform, pressure washer detergents and chemicals are useful solutions.
What is the best pressure washer?
It must meet your requirements. For example, a lightweight machine allows you to hold the washer in your hand easily for moving around. Meanwhile, you need a model that can produce more power for large tasks.
tartarus97 is offline   Reply With Quote
Old 02-24-2020, 05:25 AM   #2
Welcome to our happy little corner of the net, and to Camaro5/6. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's, wives', husbands, girlfriends and boyfriends here don't care....and take it easy.
Welcome!!
Old 04-04-2020, 09:43 AM   #3
USCAMARO14
USCAMARO14's Avatar
Drives: 2LS 2014
