Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 12-10-2019, 03:54 PM   #1
r1concepts
r1concepts's Avatar
Drives: Camaro
R1 Concepts- Performance Brakes| Carbon Alloy Geomet Rotors & R1 Brake Pads!
R1 Concepts Carbon Alloy Geomet Rotors
Manufactured for European and heavy vehicles, our High Carbon iron formulations (Molybdenum, Chromium, and Carbon) enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability. Engineered with High Carbon Castings to enhance noise dampening characteristics, while providing strength, stability, durability, and performance. Each rotor is engineered to match the OE vane configuration, including OE split-cored technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure.
The smooth finish will improve air flow as well as reduce the amount of machining required in order to properly balance the finished rotor during the mill-balancing process. Each rotor casting is sent to our state of the art machining facilities, where it is processed to the tightest tolerance in the market today. The the rotor is prepared with a non-directional finish to promote a faster and more even brake pad bed-in, along with quieter and smoother stops. Each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free.
Coating
These are specifically coated with a patented paint to form a durable and attractive silver-gray finish that fights rust far better than other conventional paint or zinc coatings. Each rotor is processed dry, shipped dry, and ready to install without any additional preparation. An average brake job takes 1.25-2.5 hours per axle. Without the need to clean an oil covered rotor, this saves a safely swept away by the friction material with no harmful effect.
V6
FT/RR CARBON ALLOY OEM REPLACEMENT ROTORS:$165 SHIPPED
FT/RR CARBON ALLOY SLOTTED ROTORS: $235 SHIPPED
FT/RR CARBON ALLOY DRILLED & SLOTTED ROTORS: $255 SHIPPED
FT/RR CARBON ALLOY DRILLED ONLY ROTORS: $255 SHIPPED
SS
FT/RR CARBON ALLOY SLOTTED ROTORS: $345 SHIPPED
FT/RR CARBON ALLOY DRILLED & SLOTTED ROTORS: $365 SHIPPED
FT/RR CARBON ALLOY DRILLED ONLY ROTORS: $365 SHIPPED
*UPDATED AS OF 10/16/2020*
Brake Pads
R1 OPTIMUM OE BRAKE PADS
R1 PERFORMANCE SPORT BRAKE PADS
R1 PREMIUM CERAMIC BRAKE PADS
r1concepts is offline   Reply With Quote
Old 12-27-2019, 07:57 PM   #2
r1concepts
r1concepts's Avatar
Drives: Camaro
Bump for new rotors!
Old 01-14-2020, 05:09 PM   #3
r1concepts
r1concepts's Avatar
Drives: Camaro
PM if you have any questions!
Old 02-12-2020, 04:51 PM   #4
r1concepts
r1concepts's Avatar
Drives: Camaro
Bump
Old 03-18-2020, 03:12 PM   #5
r1concepts
r1concepts's Avatar
Drives: Camaro
Old 04-02-2020, 05:04 PM   #6
r1concepts
r1concepts's Avatar
Drives: Camaro
We are still open for business!
Old 04-10-2020, 02:23 PM   #7
r1concepts
r1concepts's Avatar
Drives: Camaro
Special forum discount of 30% will be offered for the rest of the month! PM or email for orders!
Old 04-17-2020, 08:37 PM   #8
r1concepts
r1concepts's Avatar
Drives: Camaro
Bump for 30% promo!
Old 04-30-2020, 03:28 PM   #9
dolbnyc
Drives: 13 Camaro
PM'd
dolbnyc is offline   Reply With Quote
Old 05-11-2020, 02:01 PM   #10
Teo_916
Teo_916's Avatar
Drives: 2013 1LE
Still able to get the 30%?
Teo_916 is offline   Reply With Quote
Old 05-11-2020, 02:11 PM   #11
Domangue418
Domangue418's Avatar
Drives: 2013 camaro SS
front and rear for $330?
Domangue418 is offline   Reply With Quote
Old 05-11-2020, 05:24 PM   #12
r1concepts
r1concepts's Avatar
Drives: Camaro
Yes! I've extended the sale for all of May too.
This is before the 30% promo. PM sent.
Old 05-15-2020, 06:44 PM   #13
r1concepts
r1concepts's Avatar
Drives: Camaro
Old 07-17-2020, 03:43 PM   #14
r1concepts
r1concepts's Avatar
Drives: Camaro
Bump for the weekend!
brake pads, brakes & rotors, r1concepts, rotors
