05-11-2016, 05:33 PM | #1 |
ECS Kit on 14-15 Camaro Question
Just curious if anyone knows of folks that have installed ECS Kit on 14-15 SS Camaro, and when they did what modifications needed to be made? If any? Doing install on 14 at the moment and have run into fitment issues when it comes to radiator brackets being these were changed in 14. Couple other little issues, but those things happen (I get it). Mainly wondering about having to mod radiator brackets to clear heat shield when hood is closed.
05-11-2016, 08:09 PM | #2 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
Sorry, can't help you but I'm deciding on the ecs or agp kit and looking to install myself. So I'm guessing they don't have updated install instructions for the 14-15 camaro?
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
05-11-2016, 09:13 PM | #3 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Have you contacted ECS?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
05-12-2016, 10:13 AM | #4 |
Contacted them? That's an understatement. Finally, got to machine/fab shop that makes kit brackets. Took a while to finally get to him, but he has been extremely helpful and been back and forth on the phone with the shop working through things for last week. He too was surprised to learn of the change in 14-15.
05-12-2016, 10:16 AM | #5 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Thanks for posting this, and please keep the thread updated with the resolution. I have a 2014 and am trying to decide between the ECS kit and AGP.
05-17-2016, 05:30 PM | #6 |
Drives: 14 1LE Join Date: Jul 2013
any update? you're the only person i've heard of having problems..
05-17-2016, 06:29 PM | #7 |
Drives: 2014 Crystal Red 1LE 2SS Join Date: Jun 2015
ECS needs to step up and make the necessary changes to their kit for the 14-15 cars. Crazy to think you spend 6k for a bolt on kit and have to do custom work on top of it.
05-17-2016, 06:37 PM | #8 |
+1
05-17-2016, 08:07 PM | #9 |
hmm inbox is "full"
05-17-2016, 08:41 PM | #10 |
radiator bracketing changed. You can't expect an aftermarket vendor to keep pace with GM changes, lol
05-17-2016, 10:06 PM | #11 |
Why not? They built it for the 10-13 right? So if a small change is needed for the 14-15 models the vendor should be on top of that. Guaranteed sales will suffer if people have to buy the kit then customize it to fit their car.
05-18-2016, 05:28 PM | #12 |
apparently they're sending him new gm brackets from what jdp told me.. other than that nobody seems to have this problem..
05-18-2016, 05:51 PM | #13 |
Thats good to hear.
So no one else w a 14-15 has run into this issue? |
05-18-2016, 05:59 PM | #14 |
Thread Tools | |
