Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 05-01-2014, 06:06 PM   #1
donzi
Drives: C7 Z51 Cyber Gray Metallic, 05 GTO
Upstream exhaust valve
Can anyone tell me how the upstream exhaust valve opens & closes or does it work with the rear valve. I have the rear valve open all the time but i can hear the up stream valve opening and closing. I have an A6 Z51 npp exhaust. When the valve is opening and closing sounds like the car is choking.
donzi is offline
Old 05-22-2014, 06:03 PM   #2
transpat
Drives: 14 stingray
exhaust
I have the same deal. Mine is an auto and it happens under light acceleration around 1700 rpm. Sounds like crap. Someone said pull fuse 41 and it will stop with no check engine light lit.
Don't know what operates it though
Ed
transpat is offline
Old 05-22-2014, 08:26 PM   #3
weaponX
I'm your pusher!
weaponX's Avatar
Drives: 2014 Stingray, 1000HP CTS V, 06 H2
Yes that valve is connected to the AFM on the car to help with emissions and drone I believe. Only way to get rid of it is turn the AFM off in the tune as even the Corsas you cut after that valve and slip on so they're retained with it too.
weaponX is offline
Old 05-22-2014, 09:14 PM   #4
purpleRac3r
purpleRac3r's Avatar
The way it was explained to me is that it only operates in Eco & Touring modes for automatics, and only in Eco mode on manuals. In most situations while in those modes, it will default to open, which is to say whenever it is running on all 8 cylinders. They only close when on 4 cylinders, and only intermittently at that. Kind of a computer-controlled flutter to help offset the imbalanced exhaust pulses created by running just 4 cylinders. The valves shouldn't be operating at all in Weather, Sport or Track modes, since AFM is deactivated in those modes.
purpleRac3r is offline
