04-20-2015, 05:40 PM | #15 |
Drives: 01 Alero GLSV6/ 07 ZX-14/ 06GTO Join Date: Mar 2015
CTSV yes ATSV no..the point was it took months before any viable information was given about rhe ATSV estimated 60 3.9 estimated top speed 185 about 3700 lbs ..not terribly specific
Owned lifted 88 dakota two door short bed V6 4x4, Yellow/black LB9 powered 85 IrocZ28 MODS Edlebrock intake, throttle body spacers and mass air flow sensor, Edlebrock full exhaust, K&N drop in's, B&M 700r4 shift kit. 2001.olds alero GLSV6, BIKE~ 2007 Lazer Metallic Blue ZX-14
04-20-2015, 05:43 PM | #16 | |
http://blog.caranddriver.com/2016-ca...an-gm-thought/ CTS-V http://media.gm.com/media/us/en/gm/p...222-cts-v.html You are right if you are referring to timed performance. There's no cars on sale or available for review yet which is why.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
04-20-2015, 07:05 PM | #17 |
Drives: Has 4 wheels Join Date: Nov 2014
why do people keep thinking the Camaro will have more power than the Vet?
445hp max |
04-20-2015, 07:11 PM | #18 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
More wishful thinking than anything, Some feel the Vette will get a power boost also to keep it above the Camaro.
The Bird is the word! |
04-20-2015, 07:21 PM | #19 | |
Drives: 2012 45TH AE SS Join Date: Jul 2009
It's the same engine... It will make the same power. The only piece of info that would make us believe it will have more power is the addition of the new headers. Now having said that if the next Corvette gets the same then it will have a power increase. The guys and gals that are making the new Camaro do not care about the corvette. Their goal is to make the best Camaro that's it. |
04-20-2015, 07:25 PM | #20 | |
Drives: 2013 1LE Join Date: Feb 2012
Will they reveal HP and TQ tomorrow?
Why would they go through the effort and expense of designing and manufacturing nice exhaust headers to give it less horsepower? The simple common sense test doesn't make sense. If you plan to give it less power you give it the same exhaust manifold currently on the vette and detune it in the ECU. That's a lot cheaper and faster.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
04-20-2015, 07:49 PM | #21 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
The tri y headers would be absolutely wasted unless they were trying to squeeze more power out of the engine. The headers may be an attempt to keep power up with the longer Camaro exhaust or they might be planning to make more in the Camaro than the Corvette. If they were planning on having the usual difference in power, the Camaro would probably keep the usual and cheaper cast manifolds.
04-20-2015, 10:37 PM | #22 |
Drives: 2011 Camaro 2ss Join Date: May 2013
04-21-2015, 12:26 AM | #23 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Looks to be the very same LT1 in the Vette. I really don't think they'll do anything to change the specs of the engine, as it wouldn't really be cost effective. Of course things like air intake, exhaust piping, and driveline will effect the final output to the wheels.
04-21-2015, 07:46 AM | #24 | |
Drives: 2005 Cobalt Base - 5 speed Join Date: Apr 2015
04-21-2015, 09:08 AM | #25 |
And that resulted in a difference of 4hp. I'm pretty sure tri-ys will give us more than 4hp.
04-21-2015, 09:15 AM | #26 |
04-21-2015, 12:36 PM | #27 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Funny that 4 hp is pretty close to plus or minus 1% of 430hp. The new sae standards require them to be accurate within 1%. Gm could rate the ls3 from around 425 to 435 hp and be within limits. It's likely the same motor. It will show lower rwhp numbers in the camaro due to slightly greater drivetrain loss. Bigger wheels and some other things.
04-21-2015, 12:46 PM | #28 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
The dual mode exhaust is also worth 5hp on the corvette and it will be an option on the gen6. Unless the tri y headers only come with the dual mode exhaust I predict the Camaro hp will be what the c7 numbers are at a minimum. 455 and 460. Possibly 5 more.
Thread Tools | |
