Old 05-15-2016, 08:52 PM   #1
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Bracket Racing ZL1
Time to do a build thread.
2013 ZL1 #7860, A6, IOM, Coupe (LSA & 6L90E)
Engine, Drivetrain and Cooling Modifications:
Active Interchiller 18” Extreme Chiller, Ron Davis Heat Exchanger, Rotofab Intercooler Coolant Tank
Rotofab Cold Air Intake, Rotofab Big Gulp Air Scoop, Rotofab Washer Fluid Relocate #2, Custom DRL Delete Air Intake
Nick Williams (Boost Spec.) 102mm Throttle Body
FasterProms Ported Blower (Base and Snout)
(2.5 & 9.55 Pulley Combo) Metco 2.5” Upper Pulley with Custom Rip Cut, ATI Super Damper Lower Pulley Assembly, 9.55” Pulley, 67” 8 Rib Belt, Larger Idler Pulley
Dynatech 2” Ceramic Coated Long Tube Headers with 3” Super Catalytic Converters
Billy Boat 3” Dual Mode Exhaust with Custom 3” Connections (Full 3” Exhaust from Collectors Back)
Injector Dynamics ID1300 Injectors, DSX Flex Fuel Sensor Kit, DSX Auxiliary Fuel Pump System (Activates at 7.5 PSI), 91 and E85 Fuel
BTR Stage 3 Positive Displacement Blower Cam (Cam Motion Core)
BTR .660 Lift Dual Valves Springs with Titanium Retainers, Keepers, Locks and Seals, GM 3 Bolt Cam Sprocket, Comp Cams LS Rocker Arm Trunnion Upgrade
Circle D 3200 Stall Billet 285mm LSA 6 Bolt Torque Converter, TCI Flex Plate, Derale Remote Mount Transmission Cooler with Dual Fans, Transmission Dip Stick
NGK BKR7EIX Spark Plugs Gapped at .040, Granatelli Spark Plug Wires
Innovate Motorsports LC-2 Wide Band Sensor (Driver Side Bank, Pre-Cat)
Other Modifications:
HP Tuners VCM Suite Professional, SCT X4, Dashlogic OBDII Display Controller, Intercooler Coolant Temperature Sensor
Apex Catch Can, Metco Oil Cap Breather with Custom JRE Check Valve
RPM Chromoly 6 Point Roll Bar with Hydro Carbon Finish, Rear Seat Delete, Sparco Harnesses, Custom Harness Tank Plates, H3R Fire Extinguisher and Billet Bracket, Metco Drive Shaft Loop with Custom A6 ZL1 Bracket, SFI Rated Transmission Blanket, Biondo Bracket Racing Dial Board and Controller, Custom Console Switch Panel (Line Lock, Chiller, Fans and IC Pump), Hurst Line Lock with Switch Link Controller, Mickey Thompson 305/35/20 ET Street S/S Drag Radials, Zero Camber Rear Drag Race Custom Alignment, Detroit Speed Engine Mounts, Front Sway Bar Disconnected.
2013 ZL1 #7860 is offline   Reply With Quote
Old 05-15-2016, 08:56 PM   #2
2013 ZL1 #7860
Old 05-16-2016, 10:57 PM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Did your 60' improve with the custom alignment?
Trackman is offline   Reply With Quote
Old 06-25-2016, 08:46 PM   #4
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Your car and trailer look awesome; the attention to detail is what I expected!
TrekGTO is offline   Reply With Quote
Old 06-25-2016, 09:00 PM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Very nice! What kind of ets are you running?
ttshovel is offline   Reply With Quote
Old 06-25-2016, 09:51 PM   #6
jrhagen
Drives: Camaro
My guess would be 9.99.
jrhagen is offline   Reply With Quote
Old 06-27-2016, 09:09 AM   #7
nelspebo
Drives: camaro
nelspebo is offline   Reply With Quote
