06-01-2023, 02:06 PM | #1 |
Drives: '13 Camaro Convertible 1LT Join Date: Jul 2013
Quarter Window Seal Disappeared
2013 Vert owner .. rear passenger quarter weatherstrip was lost in my last ride with the top down. Searched interior with no luck. I'm reluctant to buy whole quarter window ($300) just to get weatherstrip replaced. Many part sites show the 2013 version is not available. I did find the 2016 quarter window for $70. Can't tell if the weatherstrip is the same as what is on the 2013 quarter window. If it is, this would be easier on my wallet than the 2013 version, assuming one could remove 2016 seal and place it on the 2013 window. Does anyone have any idea if the weatherstrip on 2016 model is same as 2013 model? TIA
06-01-2023, 02:36 PM | #2 | |
06-01-2023, 02:43 PM | #3 |
06-01-2023, 03:57 PM | #4 |
06-01-2023, 03:58 PM | #5 | ||
Thanks |
06-01-2023, 04:23 PM | #6 |
https://www.gmpartsonline.net/oem-pa...Y2LWdhcw%3D%3D
https://www.gmpartsonline.net/oem-pa...Y2LWdhcw%3D%3D Both also look like they are available on EBAY also. |
06-01-2023, 04:44 PM | #7 | |
Not applicable here .. I'm needing weatherstrip that was attached to the quarterwindow Thanks anyway |
06-02-2023, 09:33 AM | #8 |
Inexpensive Fix/Alternative
I may have found a solution that doesn't require a new window purchase. I will post back after I apply this fix.
https://youtu.be/noeLo89HXDI |
06-02-2023, 09:45 AM | #9 | |
06-02-2023, 06:16 PM | #10 |
Drives: 2024 Camaro 2SS CE Convertible Join Date: Jul 2013
Work out ? 2013 and 2016 aren’t the same.
06-03-2023, 10:26 AM | #11 |
06-06-2023, 12:11 PM | #12 |
Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
many a vert have lost that rear window seal...curious to see what you come up with!
06-06-2023, 07:13 PM | #13 | |
Window Seal, aka weatherstrip installed
Bought a 2-inch door sweep (instead of 3-inch one) from Amazon, as it was closer to the width of the original weatherstrip. I cut it to exactly 12 inches with the top at a slight angle to match the top of the rear quarter window. After removing the protective strip from the adhesive, I was able to work the bottom of the sweep between the rubber and the bottom of the glass and align the rest along the window edge. The top of the cut door sweep lined up with the top of the window. The only issue I ran into, that I haven't resolved yet, is that with the top up, when I tried to raise the rear window to the closed position, it would get half way and then auto-reverse back down into the body. After several tries, it finally would rise and seat into the channel of the top, so I left it alone, with the top up. I'm not sure what is causing the reversal, but I will try to troubleshoot it later. It is not a perfect solution, since the door sweep does not have a 'steel' back to support it, like the original. However, it does seal enough to keep light moisture out. I'm not sure if it will prevent a heavy rain from entering. The wider 3-inch may work better, but the 2-inch looks like the original strip from afar .. it's a closer match. I'll try to add pictures, as soon as I figure out how to do it here. Links for the door sweeps: https://www.amazon.com/dp/B07JPH63DZ...roduct_details https://www.amazon.com/dp/B081Q3THZN...roduct_details Last edited by sambocaesar; 06-06-2023 at 09:27 PM. Reason: Pics added |
06-06-2023, 07:43 PM | #14 | |
