Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro Convertible
Old 09-21-2020, 10:28 PM   #1
Ajs16400
Drives: 2017 Camaro SS Convertible
LT4 in tank fuel pump conversion
Who has done it? What parts are needed? If possible pictures.of the parts needed and or part numbers. How.bad was it? Are there instructions anywhere?
Ajs16400 is offline   Reply With Quote
Old 09-27-2020, 07:23 PM   #2
2SSVERT
2SSVERT's Avatar
Drives: 17 garnet red 2ss vert
The ZL1 and the SS convertible low side pump have the same part number. I can't find any other info on them so I don't know if it's the bigger pump on the SS or a smaller pump on the ZL1.
2SSVERT is offline   Reply With Quote
Old 09-27-2020, 07:47 PM   #3
Ajs16400
https://www.google.com/amp/s/wildham...eneral-motors/
I thought the same thing when i look it up on an online site. When i called the dealer with a ZL1 convertible camaro tney say it didnt match the pump number for my vin.
I foumd the info above but not sure what the difference and why this would be needed for putting the different pump in.
Old 09-28-2020, 07:33 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
part number: 19367544
also need to tune the fscm.
installation is pretty straight forward. drop exhaust and driveshaft. loosen up the subframe front bolts. disconnect lines, drop tank.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 10-10-2020, 07:15 PM   #5
Ajs16400
Since not many leave an answer when they ask a question i figured i would. Here are the part numbers needed to install a lt4 fuel pump on a lt1 convertible car. 84203866 & 84049216 cost me $134 almost $90 cheaper then wildhammers kit.
Old 10-13-2020, 09:32 PM   #6
BundiMan
The Nights Watch
BundiMan's Avatar
Drives: 22 ZL1 M6 Vert
Why do you want to replace the fuel pump?
BundiMan is offline   Reply With Quote
Old 10-13-2020, 09:39 PM   #7
Ajs16400
Going to add a supercharger and want to make sure i have enough fuel
Old 10-23-2020, 10:28 AM   #8
SLOW.VERT
SLOW.VERT's Avatar
Drives: 2016 CAMARO SS
so to conclude to the thread. for an SS convertible lt4 upgrade you need:
GM# 84244656 Pump
GM# 84203866 lines
GM# 84049216 sender unit
*CORRECTED
1st N/A 10s vert 10.85@125 Slow.vert youtube: https://www.youtube.com/channel/UC26..._as=subscriber
SLOW.VERT is offline   Reply With Quote
Old 10-23-2020, 10:48 AM   #9
Ajs16400
I was told the part number on a 2017 zl1 camaro convertible
by a dealer was as 84244656. That is the same dealer tnat gave me the other 2 part numbers.
Old 10-23-2020, 03:28 PM   #10
SLOW.VERT
SLOW.VERT's Avatar
cool fixed my last post
