06-20-2016, 07:56 PM | #1 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Affordable spring compressor
Who makes an affordable valve spring compressor or what did you use to change them?
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
06-20-2016, 08:30 PM | #2 |
Started#gottalovethatblue
I hear Harbor Freight has a cheap one. You could also borrow one from your local parts store.
06-20-2016, 08:33 PM | #3 |
Svt lol
I've heard the borrow one from parts store don't reach. That was my plan though.
06-20-2016, 09:58 PM | #4 |
I think mine is a crane tools valve spring compressor and it was 75 from summit. It works perfectly
2010 2SS/RS
06-21-2016, 05:46 AM | #5 |
Drives: 2011 camaro 2SS/RS Join Date: Jun 2015
The one advanced auto parts carries works (c-clamp) but its barley big enough and requires a death grip to get the springs compressed enough to install the keepers, but it does work. And its free (deposit only)
06-21-2016, 08:08 AM | #6 |
Drives: 2014 2SS/RS Join Date: Jun 2013
I drilled a hole into a piece of steel (flat enough to fit under the car, was a tight fit). I used big washers and nuts to compress the piece of steel over the spring by getting a couple bolts that thread into the rocker holes. Of course the hole I drilled into the steel was big enough to push the spring down and allow me to put the keepers in at the same time.
I bought cheap grade bolts for the rocker holes because I would rather the bolt bend than the head break of course and I did end up bending two bolts after finishing all 16. Overall the cost was like 7 bucks in bolts, washers and nuts. However, it was much more of a PITA. Get the tool... I'm going to end up getting one for sure. |
06-21-2016, 08:50 AM | #7 |
Drives: 2014 SS Join Date: Apr 2015
Yup! Crane's is fantastic and works perfect
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET) 2000 Trans Am - Bolt-ons 13.0@110 (sold) 2009 YZF R1 - Race bike (road course)(totaled racing) 2008 YZF R6 - Race bike (road course)(still own) |
06-23-2016, 07:28 PM | #8 |
Drives: 13' 1LE Join Date: Apr 2012
Trickflows makes one that works fantastic!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
06-23-2016, 07:41 PM | #9 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Which style are you looking for? I have a couple of these I used to change my valve springs. I did have to grind a place for the retainers to sit so they would stay in but they worked good enough for the price.
http://m.harborfreight.com/universal....google.com%2F |
06-23-2016, 07:51 PM | #10 |
Drives: 2013 1le 2ss rs black Join Date: Jun 2016
This mite do the job.....looks pretty solid.
https://www.ecstuning.com/Search/Sit...sor/ES2918793/ I get my vw maintnance supplies from ECS. |
06-23-2016, 08:29 PM | #11 | |
06-23-2016, 09:44 PM | #12 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Haha it's a strut spring compressor
06-23-2016, 10:32 PM | #13 |
that universal spring compressor wont work. it has clearance issues
06-23-2016, 10:50 PM | #14 |
