07-05-2019, 11:21 PM | #1 |
Drives: 2016 SS Join Date: Apr 2019
Zl1 wheels on 16SS Fitment questions
Hey guys I was wondering if the 6th gen ZL1 style wheels would fit on a 16SS model. If they do would I be able to use my stock tires (goodyear Eagles) on the Zl1 rims or do I need to buy new tires in order for them to fit?
07-06-2019, 12:18 AM | #2 |
You will need to get new tires in the ZL1 sizes to fit on the wheels. The stock SS sizes will be stretched too much to fit on the wider wheels.
07-06-2019, 12:19 AM | #3 |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
I have the Zl1 rims on my 2017 SS but I have the 285/305 ZL1 tires on them same as 1LE fitment. I don’t think you can fit the stock tires on the rims as they are too wide.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
07-06-2019, 12:35 AM | #4 |
Really appreciate the feedback guys. Thanks
07-06-2019, 11:50 PM | #5 |
Drives: 2017 2SS M6 Join Date: Jun 2013
what LT4Greg said and you can put 285/30/20 or 295/30/20 up front 305/30/20 in rear. i have 285/30/20 and they look a little stretched. i dont like that look.
07-07-2019, 11:43 AM | #6 |
Yes JC that’s the size on the front of my ZL1 285/30 and I’m not sure if I could run 295/30s on the front because it’s lower than an SS and might rub on the spring perches. I’m pretty sure I could run a 315/30 in the rear without problems though. Mine isn’t ready for tires yet, so I will do some research when the tires are just about gone!
07-07-2019, 03:07 PM | #7 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
ZL1 wheels yes, stock SS tires no...One issue you have to check is in the rear driver side wheel well. There is wiring harness behind the liner that would probably need to be moved due to the wider rear tire. It can rub through the liner and then the harness. It has been covered plenty on forum here and there are videos on youtube on what needs to be done to move the harness to a safer spot to accommodate the wider tires
07-07-2019, 03:21 PM | #8 |
Stock ZL1 rims and tires fit the SS perfectly. If you stay to these sizes you do not need to relocate harness
07-07-2019, 07:10 PM | #9 |
Black lightning
Even though.......there are PLENTY of people that do use there stock tires on the Zl1 setup and love it. Sure it stretches them but they don't mind. A lot of guys on This forum actually lol.
[ 2021 Camaro ZLE 10 speed
07-07-2019, 11:31 PM | #10 |
just because it can doesnt mean it should. its actually illegal in some states for good reason.
07-08-2019, 12:58 AM | #11 |
Thanks for all the replies guys. Seems to me getting new tires is the way to go
07-08-2019, 08:37 AM | #12 |
Drives: 2013 C6Z06 Join Date: Nov 2016
07-08-2019, 08:50 AM | #13 |
Yes kurage, you will enjoy your new wheels with the wider lower profile tires on your Camaro! You will have a difference in handling and the ride will be better too!
07-08-2019, 11:11 AM | #14 |
Drives: 2016 SS Convertible Join Date: Sep 2016
yes the rear tire will fit on the ZL1 front no problem. Almost all 275 tires are rated to work on 9-11" rims and most are measured on a 9.5" rim. So 10" is really a perfect size wheel for a 275 or 285 tire and doesn't stretch it at all.
