Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 02-01-2015, 08:15 PM   #1
Balrog 1LE
Balrog 1LE's Avatar
Drives: 2015 1SS 1LE
Oil...
How long does it take to burn off if spilt onto exhaust manifolds or something during oil change? Also, where should the oil line be on the dipstick for LS3? Mines way above the cross hatch marks when cold. I'm worried the dealer overfilled it.
Many thanks,
Steve
15' 1SS 1LE - Airaid CAI, VMAX Ported TB, Kooks 1 7/8 LT's w/ High Flo Cats, Elite Engineering Catch Can, Dual-Mode Fuse Pull, Tuned by Eddie @ Addiction Motorsports
Balrog 1LE is offline   Reply With Quote
Old 02-02-2015, 01:19 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
When you start the engine and the exhaust manifolds get to temperature, the oil would have burnt off.
Anywhere on the cross hatch is fine. Remember, oil expands when it gets hot. It sounds like you need to remove some oil to get the level down.
I like to add oil when it gets to the very bottom of the hatch mark, 1 full quart.
Good luck
Dimitri
Dimitrim is offline   Reply With Quote
Old 02-03-2015, 09:36 AM   #3
Balrog 1LE
Balrog 1LE's Avatar
Good luck
Dimitri
Thanks bud. The dealer must have put 10 qts in mine. its like an inch above the crosshatch when engine is cold.
Old 02-04-2015, 10:54 AM   #4
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
The cross hatch area is one qt. So use that as a guide of how over it is. An inch above is way over, make them fix it.
Russell James is offline   Reply With Quote
Old 02-04-2015, 12:51 PM   #5
Balrog 1LE
Balrog 1LE's Avatar
Just gonna change my own oil from now on. I have a very hard time trusting any dealer here in CA
Old 02-04-2015, 01:15 PM   #6
Russell James
The problem of overfill by many oil change places is caused by the way they check it. They dial in the amount into their bulk oil gun. The gun shuts off automatically at x qts. Then they start the engine, shut it off and check the oil 10 seconds later. And it shows low, so they thrown another qt in. Seen that happen a gazzilion times.
What they really need to do is wait 15 minutes for that cold oil to drain down. Then check it. Or just trust the gun Qt setting and qty that engine should take. If it's in the middle of the cross hatch after a short shut off, it will be near the top after 15 mins of sitting there. Most quickee places won't want to wait that long. So they should just trust the amount they are putting in, and go by the middle of the cross hatch if checking it 10 seconds after shutting the engine off. Cold oil takes a long time to drain down.
Old 02-05-2015, 09:21 PM   #7
songsj
Drives: 2015 2SS/RS Summit White
Yes!!! What he said, same goes for V6's except it should be 6 quarts!!
songsj is offline   Reply With Quote
Old 02-05-2015, 09:24 PM   #8
songsj
What also happens at the quickie places is they don't let all of the oil drain out, again it takes awhile and when they add 6 or 8 qts it still has up to 1 quart still in it that has not drained down. Happened to me at a dealer twice.
Old 02-06-2015, 10:59 AM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
Yeah change your own oil.
vroomapunk is offline   Reply With Quote
