05-16-2024, 05:09 AM | #463 |
Here are some pics from Saturday. I was by myself so no "in action" pics. lol
All loaded up and ready to head out - Unloaded near a shade tree at Centerville Dragway All loaded up and ready to head home. 3 time slips below with not much useful information. 1st pass after spinning at the launch and twice more before it hooked, I took it to the 1000' mark on accident but didnt have any issues stopping thankfully. 2nd pass was similar but I only went to the 1/8th mile marker After the second pass I reduced the compression & rebound quite a bit from where it was when I was at Tulsa last year. 3rd pass - It certainly hooked better on this pass until it made the 2-3 shift and the rear end started drifting. The 330' time was 3 tenths faster than the 2nd pass was, so it was certainly on a better (not great) pass. Looking to go again this weekend if the weather and everything else cooperates. Only thing I need to do to the car is pull the passenger seat back out. I put it back in on Sunday since it was supposed to be sunny some this week and had planned to drive it to work.. nope, its rained/stormed everyday so far...
05-17-2024, 10:15 AM | #464 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Looks like a blast! Keep digging at it, you will get it dialed in! Excited to see how far you go with this.
05-18-2024, 06:46 AM | #465 |
Thanks SlowLS1! I just need more time at the track and it will get there!
05-23-2024, 06:34 AM | #466 |
Installed a button so I can use the launch rev limiter functionality in the Holley ECU (MSD 2-Step function). This will also allow me to retard the timing at launch to help with traction as well.
So just watching the weather for the weekend and go where its least likely to rain.. lol
05-23-2024, 12:54 PM | #467 | |
To be honest, The Holley ECU is the way to go for adding "Functions". Don't know if I could justify the expense of the gateway, but if I ever go and build a track car, I'd ditch the the stock ECU in a heartbeat. Good luck on the weather holding out! Tuned in for updates Brian
05-26-2024, 07:35 AM | #468 | |
05-26-2024, 07:40 AM | #469 |
Had a pretty good night at Centerville Dragway last night. Made 8 or 9 passes and after making some shock adjustments was finally able to get down the track. No PB's but thats ok. Just really happy to make some clean hits.
Will load pics of the time slips and a few videos my buddy took after while.
05-28-2024, 09:49 AM | #470 |
My apologies for the delay in getting things posted. Lots of bad weather in our area, a few tornados, lots of destruction in towns close by unfortunately. Thankfully, my house and the area we live in are all good. We were without power for about 3 hours Sunday morning and then 17 hours Sunday afternoon through late Monday morning.
I will try to get things posted later today if this new pop up storm doesn't knock the power out again..
05-28-2024, 10:11 AM | #471 |
Sorry to hear about that, been some really crazy weather lately. Stay Safe brother!
05-30-2024, 04:38 AM | #472 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Yeah the weather has been crazy around the whole area! Stay safe! Are you launching in first or second?
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
05-30-2024, 08:38 AM | #473 |
Saturday I went back to Centerville again. This week it was just a test-n-tune and not a ton of cars showed up. That made for it nice as there never was much waiting to make a pass or anything and was able to make 11 passes.
Unloaded and ready to rip My buddy Daniel looking at video of the first & second pass - To start out the launch control (LC) was set to 2500rpm and launch retard (LR) taking 6 degrees out for 1.8 seconds. Pass 1 – The car wouldn’t hold 2500rpm and rolled through the staging lights twice trying to get it to hold. So I lowered the LC to 2000rpm and it worked fine after that. I probably should have tried something in the middle tho.. Pass 2 – Spun 6.95 w/1.83 60’ Pass 3 - Spun 7.98 w/2.15 60’. After watching videos I tightened up the rear shock rebound by 2 clicks. Pass 4 - 6.343 w/1.497 60’. That’s .18 slower than the best pass (6.14) and .05 from the best 60’ (1.44)! I will call that Progress!! Lol Pass 5 - 6.71 and I think I was slow on releasing the LC button on that one. Pass 6 - Tried a 1st gear launch and it spun which isnt surprising. Pass 7 – back to 2nd gear launch and a 6.41 w/1.54 60’. So the LR needs some adjustment for 1st gear launches which isnt surprising.. Pass 8 – 2nd gear, was slow on the LC release but still went 6.509 w/1.57 60’ Pass 9 / first round FB bracket – Good light (.0384) but I was slow on releasing the LC and went 6.69 w/1.65 60’. Lost that by .0016. I caught the truck and eased out of it when I should have just stayed in it and taken the light.. My reaction times have been terrible and I was hoping to the other guy would break out but that didnt happen. Pass 10 / $10 buy back – red lit – 6.70 w/1.64 60’. Pretty sure I was releasing the brake too early. Pass 11 – tried 1st gear again and spun – 1.74 60’ and I just cruised through the pass. I havent worked on reaction times at all since the car has been spinning so much. Now I can take some time and work on reaction times and also work on 1st gear launches. I need to also mess with the LR as well. More seat time is needed for sure. Its harder than I expected to coordinate letting off the brake pedal and releasing the LC.. Really looking forward to a T400, trans brake & much looser converter... lol Will probably go again next weekend as it's supposed to rain more this weekend. Couple of videos - Pass 1 - https://youtu.be/PCmoiL6UF48 Pass 4 / best pass - https://youtu.be/PDzRXeEJyac Pass 7 - https://youtu.be/1q9A3QHZZTg Pass 9 / 1st round foot brake - https://youtu.be/fDS8-Cdu8Ko Pass 11 / 1st gear launch attempt - https://youtu.be/eiFBSLytRxQ
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP Last edited by Ashen 6.2; Yesterday at 10:50 AM. |
05-30-2024, 08:39 AM | #474 |
Yes the weather for the last several weeks has been just nuts. And will do!
05-30-2024, 08:40 AM | #475 | |
I tried first gear twice this weekend. Other than that it's all been second gear launches.
