P0011 code
Just installed BTR stage 2 cam, Katech oil pump, LME wishbone, 10% lower and All supporting mods. After running for about 10 mins it threw the P0011 code. I am assuming that will be taken care of when it’s tuned? Can someone confirm this? 2017 ZL1
Could be cam position sensor issue, but since you installed a new cam, I'm wondering if it was degreed correctly.
It was definitely degreed correctly. So if that’s the case you are saying it could be the cam sensor? What about he VVT in the tune needing adjusted?
Anyone else have any advice on this?
So this means Bank 1 cam timing is advanced beyond that which was commanded. Not exactly unexpected since the ECM thinks you still have the stock cam.
I'm guessing you need some tuning parameter changes. But I'm also wondering if there is benefit to changing the cam without changing induction. |
I will find out tomorrow as I am heading to James short for tuning of the car. I will keep you all posted.
It was all in the tune! Code is cleared and running strong!
