09-18-2013, 08:58 AM | #1 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
NPP Stealth mode - added factory & wild modes
although probably not a common occurrence, i wanted to have the dual mode exhaust closed at idle. i came up with the attached fix. there are many ways to skin this cat, i chose this one because it worked for my needs and thought others could get some ideas from it.
There have been several posts looking for a method to have three NPP modes incorporated into a single switch. Stealth – exhaust flappers closed all the time Factory – flappers operate as per the factory parameters (more below) Wild – flappers always open I created a second DIY to show one way to do it
09-21-2013, 08:17 PM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Thanks again for the DIY How To man...
11-18-2013, 02:11 PM | #3 |
Drives: 2021 1LE Join Date: Jul 2011
BUMP
12-14-2013, 05:36 PM | #4 |
Drives: 2014 Camaro 1LE Summit White Join Date: Oct 2013
great write up thanks.
Ordered 10-1-13 TPW- 10-28-13 Delivered 11-12-13 |
02-23-2014, 02:47 AM | #5 |
Geoff
Single Switch, 3 Modes UPDATE
edited first post to add a DIY for a single switch controlling 3 modes
Stealth Factory Wild
02-23-2014, 10:16 AM | #6 |
Sweet, now I really want to do this. There is nothing more to want for this mod... Thanks again man.
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-23-2014, 01:49 PM | #7 |
I wish I was more electrically adept
Killed so many water bottles that day...
03-04-2014, 09:59 AM | #8 |
Drives: E92 BMW M3 Join Date: Oct 2012
Agreed, this is so awesome but I have no electrical knowledge or comfort. Sadly I think I will stll end up dropping $200 for the ADM controller, and will only have 2 functions.
J-Rod Built and Matt@FSP Tuned |
04-15-2014, 10:41 PM | #9 |
Alternate Method
Hey, I don't mean to put you down, you did a great job figuring that out and it will work perfectly that way, but there is a much simpler way to accomplish this.
You can cut the blue/yellow wire going to the rear fuse block, and wire in an on/off/on rocker switch. Here is a crude diagram of how I wired my NPP. When you're done, the 3 positions will be flaps Closed/Open/Normal. |
04-16-2014, 06:08 AM | #10 |
Geoff
Brilliant!
i did not think of that method, much cleaner.
04-16-2014, 08:31 AM | #11 |
Okay... so my electrical experience is limited but how does this last method work? You have one wire that you interrupt. I assume you cut it then a three position switch with an extra ground... how's that make this happen?
If it works I'm all for it b/c cheap and easy. I would like to understand it more though. Sent from my DROID RAZR HD using Tapatalk
04-16-2014, 11:11 AM | #12 |
Geoff
UNMODIFIED: When the controller is energized it grounds the valve relay to close the exhaust.
Inferno1LE's mod: position 1 acts like factory, position 2 opens the wire so the relay stays open, position 3 connects the relay to ground.....putting the relay on all the time Sweet & simple solution. Kinda embarrassed that I didn't think of it
04-16-2014, 04:10 PM | #13 | |
So verdict is both methods work? Sent from my DROID RAZR HD using Tapatalk
04-16-2014, 09:32 PM | #14 |
Geoff
Yep
They should both work............ Simple or Goldberg method-->same result
dual mode exhaust, npp, quiet exhaust, stealth exhaust |
Thread Tools | |
