News / Blog Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 08-23-2013, 07:48 AM   #1
jdb1218
jdb1218's Avatar
Drives: 2014 Silver Corvette Stingray
Targa top durability
My C5's targa top used to leak on the passenger side. The seal looked fine (i.e. not cracked) but water would still enter the cabin.
Any other C5 owners notice this? Any current C6 owners out there who can confirm the problem was fixed in that generation?
I had the clear top, which was prone to swirl marks (I did not use automatic car washes). Is that still an issue?
Thanks.
jdb1218 is offline   Reply With Quote
Old 08-25-2013, 05:14 PM   #2
SCM_Crash
SCM_Crash's Avatar
Drives: 2014 Z51 3LT
My C5s were both FRCs. So I never had this issue. However, the C7s have been thoroughly tested in different weather. One possible reason the water could have been leaking in might have been chassis flex allowing the seals to rub a little. The C7 has a super stiff chassis and that would alleviate that issue if that was the cause.
1997 Formula Firebird
2002 Trans Am WS.6
1990 Z32 300zx
2002 Corvette Z06
2003 Corvette Z06
2014 Corvette Z51
SCM_Crash is offline   Reply With Quote
Old 08-27-2013, 09:18 AM   #3
volsfan0911
Drives: '10 GTI for now
I know several C6 owners (with solid & clear targa tops). None have bitched about leaking. The earlier years (think Jim's is a '08?) had the squeaking issue which mostly resolves with lubrication along the seals. I don't think the polycarbonate is super sensitive to scratching but then again, it's an exterior car panel. SCM is probably dead on with less chassis flex = less/no leaking. And this will be GM's 3rd go round with this targa setup since the C5 (I'm discounting the C4 since it wasn't latched). Even they should be able to get it perfect this time!
volsfan0911 is offline   Reply With Quote
Old 08-27-2013, 09:44 AM   #4
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Cute. I had no problems on either the C5 or C6 but did go through TWO recalls on the C6 to fix the targa top, the second recall was to fix the first recall. So yes, this third bite at the apple should be perfect.
Laborsmith
laborsmith is offline   Reply With Quote
Old 08-27-2013, 12:43 PM   #5
jdb1218
jdb1218's Avatar
Thanks for the feedback everyone.
Old 08-27-2013, 01:18 PM   #6
jsvette
jsvette's Avatar
Drives: C7, XTS, Porsche, C70
Interestingly the Owner's Manual states that you should not spray glass cleaner directly on any of the roof panels, but rather spray it on a microcloth and then wipe the panel.
jsvette is offline   Reply With Quote
Old 08-28-2013, 05:15 AM   #7
SCM_Crash
SCM_Crash's Avatar
Same way you're supposed to care for TV and monitor screens.
But the truth is that you tend to not spray too much (which leaves streaks) when you spray it on the rag rather than directly on the surface of whatever you're cleaning.
2002 Trans Am WS.6
1990 Z32 300zx
2002 Corvette Z06
2003 Corvette Z06
2014 Corvette Z51
Old 08-28-2013, 02:19 PM   #8
volsfan0911
Laborsmith
a recall to fix a recall? ouch...........
Old 08-28-2013, 02:47 PM   #9
jsvette
jsvette's Avatar
I understand the logic on a TV and or monitor screen because of the electronics, but a roof panel??? It would make more sense to me if the manual stated do not spay glass cleaner directly on a hot roof panel...
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
