Old 03-14-2013, 11:45 AM   #15
sonic656
Drives: 2012 Toyota FJ Cruiser
Originally Posted by GretchenGotGrowl View Post
My boost gauge shows -PSI when idling and driving until I hit it hard. Remember, they are putting more and more electric stuff on cars so less is driven off vacuum I think. I don't think they have to run the same kind of vaccum they did 10 years ago.
Maybe im just out of the loop. I cant even find a boost gauge that shows negative on google. Vacuum sure, negative PSI, nope. Or maybe its alien technology hahaha.
6.5inHG sounds awfully low. Even with not running things off of vacuum a healthy motor still creates it with the throttle closed. I think the numbers are just a placeholder for things to come.
sonic656 is offline   Reply With Quote
Old 03-14-2013, 12:05 PM   #16
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Maybe it is a placeholder and they will change it when a ZR1-like version comes out.
I think you can make any boost gauge show -PSI if you connect the reference tube to something that reads both boost and vaccum. I'm using an AEM TruBoost, so that's pretty common. If you hook it up directly to the turbos then you only read boost. If you hook it up to the manifold it will read both boost and vaccum. We hooked mine up to the manifold because I installed a vacuum pump and it gave me an easy way to adjust the vaccum I was pulling without installing another gauge in my car. Once I got that dialed in I just left it like that.
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 03-14-2013, 01:46 PM   #17
sonic656
I know you can get it to read vacuum. What im saying is that -12 is not a number you will see on a gauge reading just PSI. 12inHg maybe since its reading vacuum but not -12PSI. The "-" on your boost gauge is just there to show you that the gauge is reading vacuum now. So -15 on aem truboost gauge is saying you have 15inhg. The positive number is psi obviously. I have never delt with those directly but have been told thats how it functions. Since its just leds and does not actually say "PSI or inHg" on the gauge. If it really was reading -15psi that would be a very unhealthy engine with very little vacuum.
Which brings me back to why the C7 gauge says PSI but yet have a negative number. Its probably just a placeholder though ya.
Old 03-14-2013, 01:52 PM   #18
ec1990
Drives: 2012 AGM SS
It could also be a software thing for future. Why not use the same software for all models, even though there's no use for it in a NA car, a boost gauge could have a use in future vehicles.
Also what options did that car have? It looks like either a 2LT/3LT Z51 car with carbon fiber interior package.
ec1990 is offline   Reply With Quote
Old 03-14-2013, 04:29 PM   #19
Bruno
Drives: 2010 CGM 2SS
Woo supercharged or turbo motor coming??
Possibly Z06 and ZR1 both going forced induction?
Bruno is offline   Reply With Quote
Old 03-14-2013, 05:53 PM   #20
nguyennhatquang
Drives: Cadillac
i hope the Z06 or ZR1 will be a revolution.
they should have DCT or at least Tapshift automatic in them.
the low volume sell of Z06 or Zr1 now because the lack of DCT or Auto..
nguyennhatquang is offline   Reply With Quote
Old 03-14-2013, 06:58 PM   #21
shank0668
shank0668's Avatar
What were his impressions?
Old 03-14-2013, 06:59 PM   #22
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
Great pics. The boost gauge on the ZL1 is formatted the same way; reads vacuum in hg at idle and psi when in boost.
BTW - How does this site always get the cool pics first, hmmm?
DrkPhx is offline   Reply With Quote
Old 03-14-2013, 07:13 PM   #23
sonic656
Ya but what Im saying is that the one in the C7 does not read inHg. Its just PSI, which is not correct. Even if the -12 was supposed to stand for 12inHg thats pretty low vacuum.
Old 03-14-2013, 07:29 PM   #24
DrkPhx
DrkPhx's Avatar
Good point. I didn't see the negative by the lower 12. Mine start at 30 in hg and goes to 15 psi for boost. Though I did set up a pid in my scan tool to log boost (only in psi) and it shows a negative boost number in psi at idle even though it's technically not negative boost.
Old 03-14-2013, 07:36 PM   #25
sonic656
Ya I mean there is a formula to figure out what "negative" PSI would be in vacuum terms(inHg) but -12 is only like 5 or 6inHg. Its probably just there as a place holder for bigger things to come. Im just looking into it too much probably hahaha
Old 03-14-2013, 07:51 PM   #26
DrkPhx
DrkPhx's Avatar
-12 in hg converts to -40 kPa which is definitely not correct. You're probably right, it's probably there for another model. Perhaps the rumored twin turbo big brother motor for the top of the line C7?
Old 03-14-2013, 08:06 PM   #27
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
OK, what do I need to do to have GM give me a prototype to test and drive??? Talk about hitting the lotto. I can test a car year round without any hint of snow or ice. Good pictures even if they are taken with a cell phone.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 03-14-2013, 10:15 PM   #28
volsfan0911
Drives: '10 GTI for now
LMAO - I'll sacrifice myself and do some altitude testing as well if they need it. Maryland International Raceway (such a grand name for a dragstrip) has an elevation of a whopping 80' ASL It's only 80 miles from my front door and then I have Capitol Raceway outside the Beltway for verification I will need to make multiple passes naturally, to validate the results....
volsfan0911 is offline   Reply With Quote
