News / Blog Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 01-25-2013, 10:23 PM   #1
ec1990
Drives: 2012 AGM SS
Rev Match Question
So now that the manual has a rev match feature maybe someone with a 370z can answer this.
Is there a safety mechanism that prevents it from over-revving? Say for example you're going 70 and go to downshift to 3rd but put it in 1st, will it over-rev itself trying to rev match or will the computer step in and not allow it to rev match? Granted I figure there's nothing that can be done to prevent you trying to going into that gear if you still shift and seeing shiny metal pieces fly everywhere.
ec1990 is offline   Reply With Quote
Old 01-25-2013, 11:31 PM   #2
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Not sure how the rev matching works, but the ZL1 has no lift shift which means gas on the floor all the time. Motor will only rev to the limiter during your shift. Pretty much a fail safe if you're a slow shifter.
I use it all the time and it works great.
Old 01-25-2013, 11:38 PM   #3
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Im at a loss as well.
Dummies like me need these safeguards....Murphys law at work.
GaBoy25 is offline   Reply With Quote
Old 01-26-2013, 12:02 AM   #4
OctaneZ28
Camaro Disciple
OctaneZ28's Avatar
Drives: 2013 Camaro 2SS/RS
Send a message via AIM to OctaneZ28 Send a message via Yahoo to OctaneZ28
The rev limiter will step in to prevent over-revving.
I believe there's a set range of RPMs that it will rev match in (but don't quote me on that), not below the range and not above the rev limiter.
2013 Camaro 2SS/RS
OctaneZ28 is offline   Reply With Quote
Old 02-01-2013, 11:16 PM   #5
C7Z51
If your go from 3rd to 2nd instead of 3rd to 5th at WOT. No rev limiter will protect you. As I read it, it won't let you make that mistake
Always Had a Vette and Hope I Always Will
C7Z51 is offline   Reply With Quote
Old 02-07-2013, 11:25 PM   #6
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
So are you a slow or just lazy?
The is one tech feature I'd like to see make its way to the Camaro. I have tried blipping the throttle to rev match and I am not good at it.... I keep trying.
tramtwo is offline   Reply With Quote
Old 02-08-2013, 07:28 AM   #7
ec1990
Drives: 2012 AGM SS
Just takes practice, it's a pretty minor movement so just practice if you over-blip the throttle just keep the clutch in for half a second longer until the RPM's drop. Or you could try seeing how much throttle movement gives a certain response, so how much does it take to raise form 2000 to 3000 RPM's, etc...
Old 02-19-2013, 06:00 PM   #8
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
I agree, I'm not that great with rev matches on the Camaro.
Old 03-29-2013, 10:02 PM   #9
volsfan0911
Drives: '10 GTI for now
I'm a terrible granny shifting fool. As far as downshifting into 1st rather than 3rd? Never done that one. You'd have to be trashed or severely distracted IMHO to not tell you're in 1st rather than 3rd The fuel cut-off hopefully will save your ass but that would be a nasty sound (and horrible feeling probably as you realize you just grenaded your motor). People tell me that heel & toe work is just a matter of practice but I have relatively small feet (size 8) and most cars I've driven in the past weren't really blessed with pedals well positioned for me to learn this skill.
No lift shifting would scare the hell out of me. I've been in a Cobalt SS with the driver using that feature - it was fast but damn I thought the powertrain was a goner. Chevy swears the motor will handle it though and if you watch the ZL1 instructional video, it stresses that you need to stay 100% in the throttle and quickly jab the clutch to make the system work as advertised. IIRC. Personally, I don't foresee myself making any no lift shifts. Although, ironically, it would be nice on my GTI since it would allow me to stay in the boost on upshifts. But I don't drag race it so not a big deal for me right now.
volsfan0911 is offline   Reply With Quote
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
