News / Blog Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 01-23-2013, 11:21 AM   #1
Bolt-onC6
Drives: 2017 Corvette
Do we know gear ratios?
Have not read anywhere what gear ratios come in the 7 speed manual tranny or what differential gearing is standard or comes in the Z51. I would assume the 6 speed automatic is the same as C6.
Bolt-onC6 is offline   Reply With Quote
Old 01-23-2013, 11:39 AM   #2
OctaneZ28
Camaro Disciple
OctaneZ28's Avatar
Drives: 2013 Camaro 2SS/RS
Send a message via AIM to OctaneZ28 Send a message via Yahoo to OctaneZ28
The only gear ratio I've heard so far is the rear-end on the manual, which will be 3.42.
2013 Camaro 2SS/RS
OctaneZ28 is offline   Reply With Quote
Old 01-23-2013, 11:58 AM   #3
Bolt-onC6
That's fine as long as the tranny first gear is low. Like a 3.50 ratio. That 2.66 first gear won't get the job done with 3.42 out back.
Old 01-23-2013, 05:47 PM   #4
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
My car at least has a 3.06:1 first gear! Now if I had 3.42's out back first gear might become useless..
Vette TPI is offline   Reply With Quote
Old 01-23-2013, 05:55 PM   #5
Bolt-onC6
Cars with any good amount of power will find 1st gear almost useless with street radials. Got to have sticky tires even on the street. Drag radials is a must on the street for my Corvette.
You don't want to gear a car so that when you get to the track you can't 60' due to too tall gearing when set up right with stickys. Get the right gearing for the car even if you can't hold traction on the street on street radials.
Old 01-23-2013, 06:57 PM   #6
Vette TPI
Vette TPI's Avatar
I agree, would the same still apply if I had a turbo set up?
Old 01-23-2013, 07:53 PM   #7
Bolt-onC6
Depends on whether you have an automatic or a manual tranny. Definitely need a low first gear with any manual car even with a turbo if nothing more than to save the clutch on those hard launches on sticky tires. Assuming we are talking street/strip cars, a multiple of about 12-14 (first gear x differential ratio) is a good number for a manual car. With an automatic car a low gear isn't nearly as critical if you have the correct converter stall rpm. You can run awfully good with even a first gear multiple of 10. With a properly sized converter you can actually go too low first gear and run same or slower than with taller gearing.
Old 01-23-2013, 08:42 PM   #8
Vette TPI
Vette TPI's Avatar
Okay, makes sense. Thank you!
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
