News / Blog Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 01-22-2013, 01:08 PM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Post Primer on the LT1 V8 Engine (by Automotive Engineering International)
An article on the LT1 from Automotive Engineering International:
Name:  Screen Shot 2013-01-22 at 10.05.04 AM.jpg
Name:  Screen Shot 2013-01-22 at 10.05.13 AM.jpg
Name:  Screen Shot 2013-01-22 at 10.05.24 AM.jpg
Name:  Screen Shot 2013-01-22 at 10.05.32 AM.jpg
Tran is offline   Reply With Quote
Old 01-22-2013, 01:45 PM   #2
ec1990
Drives: 2012 AGM SS
What's the weight comparison of the LT1 to the LS3?
ec1990 is offline   Reply With Quote
Old 01-22-2013, 02:10 PM   #3
OctaneZ28
Camaro Disciple
OctaneZ28's Avatar
Drives: 2013 Camaro 2SS/RS
Send a message via AIM to OctaneZ28 Send a message via Yahoo to OctaneZ28
LS3 in crate form is 415lbs
LT1 in ready to run form is 465lbs as stated in the article above.
2013 Camaro 2SS/RS
OctaneZ28 is offline   Reply With Quote
Old 01-22-2013, 02:30 PM   #4
ec1990
Drives: 2012 AGM SS
What does the LS3 not include in crate form by chance?
So overall the weight difference is almost negligible?
Old 01-22-2013, 03:35 PM   #5
OctaneZ28
Camaro Disciple
OctaneZ28's Avatar
I'm not really sure.
I guess we'll know when the LT1 is available as a crate engine, but that's a ways off.
But I would agree with the assumption that the weight difference is probably negligible.
2013 Camaro 2SS/RS
Old 01-22-2013, 03:45 PM   #6
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Especially with the increased output
GaBoy25 is offline   Reply With Quote
Old 02-13-2013, 04:53 AM   #7
imported_THE EVIL TW1N
imported_THE EVIL TW1N's Avatar
Hopefully they've fixed the piston slap issues that have long plagued the LS series engines. This engine looks pretty good, I wonder if the days of slapping on a carb on them are over with all the tech packed into them.
They should have given more information in the article such as the flow numbers in comparison with the outgoing heads, the strength of the crankshaft... etc. Also, the V6 is intriguing, but very little info too.
imported_THE EVIL TW1N is offline   Reply With Quote
Old 12-30-2013, 10:17 PM   #8
bnall40
Drives: Z51 3LT, 2009 Pilot, 2012 Ody Tours
The Chevy small block engine is iconic and especially exciting with the LT 1 refinements. It is clear that GM has gone all out to produce a very special engine. I am delighted to own an LT 1 (Z51) because of the outstanding performance and it appears that the government will make it obsolete in the not too distant future,.... then it will most certainly become an all time collectors item. For me, too, a special connection to the past; my first car was a new 1956 Chevy Bel Air, small block V8 with power pack. What a car!
bnall40 is offline   Reply With Quote
Old 12-31-2013, 11:39 AM   #9
zimm888
zimm888's Avatar
Drives: 2014 Stingray Z51
Premium octane fuel recommended, but not required. Sweet for those days at the pump when you're feeling like a cheapskate and you won't be driving anywhere special for the next week or two.
zimm888 is offline   Reply With Quote
Old 01-13-2014, 12:23 PM   #10
topper
Drives: audi 2.0tfsi
BSFC is 330 g/kW.h in normal mode and 270 g/kW.h in cylinder deactivation mode ? how is that possible. it does not look logical to me. when only 4 cylinders are working they still will have to move other 4 cyl.-s too. so the combined BSFC of the whole engine will get worst !
topper is offline   Reply With Quote
Old 08-14-2014, 08:56 PM   #11
I-VETTE
I-VETTE's Avatar
Premium Gas for LT1?
Do you mean for the LT1? Premium is not required????
I-VETTE is offline   Reply With Quote
Old 08-15-2014, 08:46 AM   #12
purpleRac3r
purpleRac3r's Avatar
That's what the article mentions, which is pretty amazing. Look at the short paragraph immediately below the photo on the red C6. Premium is recommended but not required. I myself had to run a tank of 89 octane fuel (91 or 93 wasn't available at one point on a long road trip). I experienced no problems, maybe a slight performance drop at most.
purpleRac3r is offline   Reply With Quote
Old 08-15-2014, 10:52 AM   #13
route66
Drives: 66 coupe 78 pace car 2014 coupe
This is what I have in the owners manual for octane rating statement. Under what section has anyone found the lower
octane ratings recommended.
Fuel
TOP TIER Detergent
Gasolines.
Use premium unleaded gasoline
with a posted octane rating of 91 or
higher. If the octane is less than 91,
you could damage the engine and
may void your vehicle warranty.
If heavy knocking is heard when
using gasoline rated at 91 octane or
higher, the engine needs service.
route66 is offline   Reply With Quote
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
