Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic Maintenance - Wash, Wax, Detailing, Exterior Repairs
Old 03-21-2017, 08:28 AM   #1
psalmon123
Drives: 2015 Z07 2017 ZL1
MICE!!!
Anybody have any solid ideas on keeping mice out of cars that are not driven everyday. We have had an abnormally long cool winter and they are extra bad this year (Have caught 30+ already). I have a Z06 that they have got into and screwed up. With the new ZL1 arriving any day, I want to try to get ahead of it. I've heard mixed reviews on Bounce. Thanks
psalmon123 is offline   Reply With Quote
Old 03-21-2017, 09:18 AM   #2
Realist
Realist's Avatar
Drives: No Camaro :(
Cats
Years ago I found mac and cheese in each of the air boxes of our s10 blazer and pickup that mice were storing. Spend sometime locating and sealing any access holes into the garage. Traps, kill food and those electronic plugins may assist as well but it's probably going to be a constant battle.
Realist is offline   Reply With Quote
Old 03-21-2017, 09:32 AM   #3
snackbar64
snackbar64's Avatar
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR,
Glue traps surrounding the tires.
snackbar64 is offline   Reply With Quote
Old 03-21-2017, 09:33 AM   #4
pgviper
Drives: 67 Pro Touring Camaro
Send a message via AIM to pgviper
Cats - they kill everything.
pgviper is offline   Reply With Quote
Old 03-21-2017, 09:49 AM   #5
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Even if they don't get eaten, cats will scare them away. Just keep a couple of cats in the garage and it will be fine....and of course and place so they can go in and out.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 03-21-2017, 09:52 AM   #6
OH2017ZL1
Drives: 2017 Zl1
Moth balls all around foundation of garage on the outside. Then they make a moth ball like bag you can get at a tractor supply store. Set those inside the garage around all the garage doors etc and places you think they may get in after you seal it up. THis should fix the problem. Then a barn cat always helps.
OH2017ZL1 is offline   Reply With Quote
Old 03-21-2017, 09:55 AM   #7
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Bounce dryer sheets
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 03-21-2017, 10:08 AM   #8
psalmon123
Unfortunately we have two bulldogs that would end the cat Solution!
Old 03-21-2017, 10:19 AM   #9
thornstein
Drives: 2016 Camaro SS
Go to the farm store and get some black bait boxes and the blocks of mice killer with the hole in the middle. Drill a hole in the bottom of the bait box and use a landscape nail to secure it to the ground. Put one on each side of your garage or outbuilding. Put the bait on the steel poles inside the bait box so the mice can't take the blocks out of it. The bait box locks shut, keeping kids and animals out of it.
Put 6 to 10 blocks in each one at first. Check them after the first week, refill in needed. Then check them after 2 weeks, then every month. You'll notice the bait getting hit less and less each time you check it. Once you decimated the population, you'll only keep 2 to 4 blocks in each one to keep the bait fresh and then check it once a month. If you are faithful to the schedule, you won't have any mice problems. If you let a box sit empty, they'll start coming back. The bait is outside and the mice will go looking for water when they eat it. keeps them outside and they die off.
I run a food production facility. We have zero mice because of this pest control program. I have a cabin at a lake and this method keeps that clear of mice as well. It's almost fool proof but you have to be loyal to the schedule. Once a month is pretty easy insurance to keep them out of your car.
thornstein is offline   Reply With Quote
Old 03-21-2017, 11:20 AM   #10
HDRDTD
Just store the car in one of these 'bubbles', and it'll keep all critters away from it.
http://www.calcarcover.com/product/7...Storage_Bubble
Old 03-21-2017, 12:23 PM   #11
Stoner
Drives: 2017 ZL1 HBM, M6
Great idea, but we must have super mice here. They will eat through a hard plastic garbage can to get inside. That plastic bubble would not do much to slow them down.
Stoner is offline   Reply With Quote
Old 03-21-2017, 02:13 PM   #12
psalmon123
Best suggestion. Thanks, Phil
Old 03-21-2017, 03:42 PM   #13
buck50
Drives: 2021 C8, 2022 Camaro 2SS
In the past I used the baits as mentioned above. Two winters ago a friend put me on to the Victor M793 Ultra Sonic Pest Chaser Rodent Repellent. I was skeptical but put two in two different garages. I also setup some traps in both garages. Mice are gone! Have not caught a single mouse in the 6 traps over the last two winters. A side benefit is the spiders that used to like my one garage are also gone.
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
Old 03-21-2017, 04:40 PM   #14
SC552
SC552's Avatar
Drives: 2017 Lingenfelter Camaro ZL1 Coup
Thanks
Don't know about mice but Rid-a-Rat has kept pack rats away here in AZ. Bobcats do a good job but don't want them in your garage.
SC552 is offline   Reply With Quote
