07-23-2015, 04:16 PM | #1 |
Engine out...ERL forged 427 coming soon
Just yanked the stock LS7 and am awaiting the arrival of the ERL forged 427 I ordered.
07-23-2015, 04:23 PM | #2 |
Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
Good luck!
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 |
07-23-2015, 04:40 PM | #3 |
Drives: 2014 Z/28 Join Date: Jun 2013
Hopefully the new motor will serve you well. Have been following your process.
2016 Z06
2017 ZL1 2015 Lexus IS250F hers 2016 Chevrolet 2500HD tow rig |
07-23-2015, 05:16 PM | #4 |
Drives: '13 Roush S3 '16 Ram Sport 4X4 Join Date: Apr 2009
Should be beastly.
Will be watching for sure. Good luck! |
07-24-2015, 02:14 AM | #5 |
Drives: 2014 Camaro Z/28 Join Date: Jun 2015
what you doing with the old motor?
07-24-2015, 06:01 AM | #6 |
core charge...it is toasted.
07-24-2015, 10:11 AM | #7 |
Drives: 2015 Z28 #516 Join Date: Jun 2015
The stock block has your VIN number and production dates to match your Z28. The VIN number is located on the deck (drivers side rear) shown in one of your pictures. It would be better to keep it and just pay the core charge. You never know what the collectability will be on these Z28s.
. Last edited by 2015Z28; 07-24-2015 at 10:25 AM. |
07-24-2015, 10:21 AM | #8 |
Drives: 2014 1LE Join Date: Oct 2013
Following you, man. Hope to meet up with you at the track some day.
07-24-2015, 11:32 AM | #9 |
Drives: 14 1le Join Date: May 2012
You can have erl sleeve your block and not a new core so you keep your matching numbers. That's what I did on my gto.
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold 06 Z06 500 rwhp sold 10 2ss ERL 427 530 rwhp sold 14 1ss 1le |
07-24-2015, 12:45 PM | #10 | |
To the OP, what crank, rods, and pistons are you running?
07-24-2015, 01:01 PM | #11 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
I'm surprised you pulled the motor with the hood still on the car. Didn't that make it a little tight to get the clearance needed to get the cherry picker in there and remove the block?
2015 Z/28 #642 Black Bad Ass
07-24-2015, 01:57 PM | #12 |
It was tight but it barely cleared. It took patience and that motor tilting device to gently get it past the tight areas. I took the strut loose but found it was only worth about an extra 2" so I just left it in place. Cracking the paint on the hood bolts wasn't something I wanted to do.
07-24-2015, 02:21 PM | #13 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
Can you give us the details on the new forged 427 please.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
07-24-2015, 04:22 PM | #14 |
package M2 with total seal rings...http://www.erlperformance.com/gm-ls-...e-short-blocks
