Vararam
Old 03-01-2016, 11:50 AM   #295
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Dmpsix View Post
I think I read somewhere on this thread... maybe it was this thread, that this doesn't apply if you're tuned?
Maybe I'm confused with that gas fuse pull thing and letting it sit overnight.
You are thinking about the fuse pull. This is a hardware issue. You can't get around it with software.
Old 03-01-2016, 12:02 PM   #296
tdsikk
tdsikk's Avatar
Drives: 2SSRS
I just had my car tuned after install of an AGP kit and was wondering if the switch to a strong MAF required a retune?
tdsikk is offline   Reply With Quote
Old 03-02-2016, 11:49 AM   #297
Apex Motorsports
To be honest, I am not 100% sure. It is possible that it will need an update.
Old 03-09-2016, 01:35 PM   #298
Teknolla
Drives: 2010 2SS/RS
Planning on pulling my MAF today to check, but in the meantime I noticed it says "out of stock" on your website. In case I need it, when do you plan to have some?
Teknolla is offline   Reply With Quote
Old 03-09-2016, 05:46 PM   #299
Apex Motorsports
We have them on order. Just waiting for them to come in.
Old 03-19-2016, 07:55 PM   #300
InfernoB
Drives: Camaro 2SS RS L99 Blk with IOM pkg.
I have a 2011 SS L99 which has a "weak MAF", (according to the identifying technique you described); however, at idle with my AC OFF it reads from 1850-1925 Mhz? Perhaps identifying the weak MAFS is not as easy as it seems? Is my mMAF still weak? I never read the readings during a data log at full throttle....
InfernoB is offline   Reply With Quote
Old 03-20-2016, 04:22 PM   #301
Apex Motorsports
We do not recommend swapping for the sake of swapping. As long as you don't encounter the drivability issues after induction upgrades described you have nothing to worry about.
Old 05-02-2016, 02:36 PM   #302
samman11
Drives: 2011 Camaro SS Convertible
I installed a new CAI from Cold Air Inductions this weekend. NICE! I checked my MAF, and the strangest thing is that it had NO letters or numbers within the area where the code is supposed to be within the recessed part. Just some very small looking symbol of some sort. I have a 2011 SS convertible. Anyway, it runs perfect with no idle issues and moves like hell.
samman11 is offline   Reply With Quote
Old 05-02-2016, 03:57 PM   #303
Apex Motorsports
If you can, post a photo of it. Typically an intake alone is not enough to cause problems and as long as you are not having any there is no reason to worry.
Old 05-03-2016, 08:20 AM   #304
samman11
Ok, I'll have to remove it again to do that, but it's not a big deal. I'll post one soon. (oh boy, I'm new to my Iphone and this site. How exactly does one post a picture from their Iphone to here?)
Old 05-03-2016, 06:14 PM   #305
sscamaro89
2Ss89
sscamaro89's Avatar
Drives: 2ss/Bumblee Bee
so im going to check my sensor when i get home, my question is can i go with an aftermarket sensor and ill be ok or do u recommend to go with the stock.
2Ss89
sscamaro89 is offline   Reply With Quote
Old 05-10-2016, 06:51 PM   #306
Apex Motorsports
There is no such thing as an aftermarket performance MAF sensor. There are only shady companies that put their sticker on a factory MAF and lie about it.
Old 05-12-2016, 12:11 AM   #307
sscamaro89
2Ss89
sscamaro89's Avatar
appreciate the response I was going to buy the jet flow one that cost 158 but good to know
2Ss89
Old 05-12-2016, 05:46 PM   #308
Apex Motorsports
No problem. Save your money.
apex, bucking, maf, surging, weak
