AWE Tuning
Old 08-13-2016, 10:35 AM   #1
mikeyg36
Drives: 2015 Z/28 #533
LT1 Normal Oil Pressure Range
I'm probably being incredibly paranoid about the pick up tube recall but I feel like the idle oil PSI has dropped since when I first got the car. While idling on a warm engine it's sitting around 28-29 PSI. Is this around what everyone else is at?
Old 08-13-2016, 02:12 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I've noticed my oil press. has also always been much lower than my LLT V6.
Never greater than 40 even at start-up (hot weather since I got the car).
I'm sure it's dropping down in the 28-30 range when warmed up and at idle.
Ventmaster is offline   Reply With Quote
Old 08-13-2016, 02:17 PM   #3
mikeyg36
I know it'll definitely be lower than the V6s with the DOHCs and all the other valvetrain parts. I'm pretty sure those engines used to hit the peg on a cold start.
Old 08-13-2016, 03:31 PM   #4
Tmcbigblue
Drives: 2016 1ss black 6m
I'm in my ss now at warm idle and just a hair under the 30 mark. So the same as your ss.
Tmcbigblue is offline   Reply With Quote
Old 11-18-2016, 08:11 PM   #5
DadsCam
Drives: 2016 SS 6M, Mag Ride, Dual Ex
Here's the thread I was looking for. Just watched mine for the first time SS, 28-29 fully warmed up at idle and lower rpms. Gets up to a little under 40 under rpms. Was wondering if this was normal myself. Seems like it is.
DadsCam is offline   Reply With Quote
Old 04-02-2019, 02:31 PM   #6
UrMaster
UrMaster's Avatar
Drives: 2016 Hyper Blue Metallic 2SS
Mine sits about 30 maybe lil less when hot idling and 35 cruising. Rarely goes upto or over 40 unless I go WOT at which point only at very high rpm does it hit 50 or so. Is that normal? This is my second 2016 and I could have swore my first one had a little higher pressure then this.
UrMaster is offline   Reply With Quote
Old 04-02-2019, 02:42 PM   #7
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Mine has been about the same for 3 years and 21K miles . I dont worry about it.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 04-02-2019, 02:48 PM   #8
EGOKLR
Drives: 2017 Camaro SS
factory oil pressure specs are 22psi at 1000rpm, 30psi at 2,000 rpm, and 33psi at 3,000 rpm. So yes, that will be normal.
The relief valve (should) stop oil pressure from exceeding between 55 and 75 psi.
EGOKLR is offline   Reply With Quote
Old 04-03-2019, 06:49 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
As long as oil pressure increases with rpm then it's fine. Idle pressure does not need to be very high.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 04-03-2019, 10:03 AM   #10
TRich2SS
Drives: 2016 Camaro 2SS Summit White
TRich2SS is offline   Reply With Quote
Old 04-03-2019, 11:35 AM   #11
MackSteelPrivateEye
Drives: 6 on the Flo' Super Sport
Not like old cars....OP now fluctuates depending on the engines requirements. No longer just what the pump pumps out. All controlled by sensors now.
MackSteelPrivateEye is offline   Reply With Quote
Old 08-14-2021, 09:33 AM   #12
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
Should I expect a difference in pressure when I run 5-40 oil per the track-prep guide for track days? When I run the standard 5-30 I run slightly below 40 PSI. When I run the 5-40 I am closer to 45. Both these PSI readings are "most of the time" readings, meaning when I look, that's where they are.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 08-14-2021, 09:55 AM   #13
KingLT1
KingLT1's Avatar
Yes thicker oil will increase pressure.
2016 NFG 1SS A8
Old 08-14-2021, 01:47 PM   #14
s346k
s346k's Avatar
Drives: like an old lady
at operating temp mine shows 30 psi idling, and it gradually increases to around 55 psi with rpm up to 6100 or so. at 6100 it jumps to 70+ psi. oil weight doesn't seem to make a difference. i've had 5-30, 0-40 & 5-40 in it. all the same except the heavier oils make a little more pressure when cold below 5k rpm.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
