BeckyD @ James Martin Chevy
Old 03-05-2016, 04:02 PM   #1
Roto-fab 1
Roto-fab 1's Avatar
Drives: 16 Camaro SS w/ Roto-fab CAI
Roto-Fab CAI for 2016 Camaro SS Sneak Peak!
We’ve received many questions about the progress of our 2016 Camaro SS cold air intake system. Our first air box prototypes were aluminum construction similar to our 5th Gen Camaro system. However, OEM plumbing in the lower air box area made it impossible for us seal off the lower area from hot engine bay air. Therefore, we elected to design a polymer air box which actually engages the stock air intake duct and is otherwise fully enclosed when the hood is shut. And yes, it does effectively seal to the hood. As you can see, our air box inlet is substantially larger than the stock inlet. Rather than butt up and reduce in size, the Roto-fab air box engages the stock rubber inlet on the car and actually forces it open to create a larger cross section for increased air flow. Like our other intake systems, no tuning is required and no modifying your vehicle or its components is necessary.
The attached photographs show the air box as made from the actual tooling which will be used for production along with the actual filter we plan to use. However, the duct work is for illustrative purposes only. That being said, the final version will be very similar in appearance. We will keep you guys updated on the progress as we move farther along!!
Thanks,
Jeremiah
Roto-fab 1 is offline   Reply With Quote
Old 03-05-2016, 04:54 PM   #2
jimmypop13
Drives: 2016 camaro ss
Very cool. Can't wait to see results
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 03-05-2016, 06:19 PM   #3
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Looks GREAT!!! Can't wait to see detailed info on this and not just X hp/tq!
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 03-05-2016, 11:24 PM   #4
neal_zack
neal_zack's Avatar
very cool!
Summit white, 2SS, Ceramic white interior, 6 piston brakes, Black Bowties, 6 Speed,3.9 sec 0to60 NPP,MRC,NAV,RX Catch can
neal_zack is offline   Reply With Quote
Old 03-06-2016, 05:43 AM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Thanks Mike, I know it will work as claimed. Hope you get them out soon and I know the last time we talked you were feeling much better. Glad to hear that.
Old 03-06-2016, 12:47 PM   #6
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Sweet! A ton of products to compare while I await my car
Sledgehammer70 is offline   Reply With Quote
Old 03-06-2016, 01:27 PM   #7
08z51c6
Drives: 2016 Camaro SS - A8, MRC, NPP
I see a CAI comparison test in the near future
Delivered: 2016 SS Nightfall Grey - 1SS, MRC, NPP, A8
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
08z51c6 is offline   Reply With Quote
Old 03-06-2016, 02:21 PM   #8
Zodiac
Sarcasm Personified
Drives: 2017 Charger R/T Scat Pack
Awesome setup, looks great! Loved the Roto-fab on my G8. Jealous you don't make any for the Mustang.
Looking forward to real world results and testing.
Zodiac is offline   Reply With Quote
Old 03-07-2016, 09:25 AM   #9
Kracka
Drives: 2021 Corvette Z51
Very nice! Looks OEM in design too; similar to the stock Z/28 intake. So far this is my favorite of the aftermarket gen6 SS intakes announced.
Kracka is offline   Reply With Quote
Old 03-08-2016, 10:06 AM   #10
Roto-fab 1
Roto-fab 1's Avatar
Glad to hear it! We are working around the clock to get it finished and sent out for testing. We are also working on a short informational/install video which we are hoping to have uploaded by the first of next week.
Thanks,
Jeremiah
Old 03-08-2016, 10:25 AM   #11
TSloper
Is this design the output of actually measuring pressure differentials along the factory intake path and finding actual restrictions? Everyone is quick to get to their dyno results but so far not one company has offered anything that constitutes a measured restriction on the car under actual engine operation. Flow benches aren't needed. A simple differential pressure meter will locate areas of significant restrictions.
Hopefully someone will eventually separate unintended spark/fuel changes from actual legitimate mass air flow improvements when they put up their dyno numbers. Right now I would say no one has shown the stock intake on a stock engine to be a problem that needs a solution.
TSloper is offline   Reply With Quote
Old 03-08-2016, 11:41 AM   #12
Kracka
That data has already been posted by one of the vendors or a tuner, it showed the stock intake to be a restriction. I don't recall who posted it, but I know it's on this board somewhere.
Old 03-08-2016, 11:44 AM   #13
TSloper
You mean the one post showing the MAP sensor reading drop on a WOT run?
Old 03-08-2016, 11:45 AM   #14
Kracka
Even if vendors are measuring this specific data you request, which I know some are, they aren't going to share it with their competitors by posting it online as it's proprietary R&D data. It is no secret that stock intakes and paper panel air filters pose a restriction vs. a freer-flowing aftermarket system with a larger, and less restrictive, air filter. Are the gains going to be massive or magical? No, but the C7 guys are typically finding ~10whp to be accurate in independent testing (plus keep in mind the C7 already has a larger stock air filter than the gen6 SS does).
