Old 04-08-2019, 11:45 AM   #15
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Just for jollies FYI....
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 04-08-2019, 11:47 AM   #16
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Without looking at the manual, I had to add close to 11 to get the proper amount via the dipstick. FYI, using 15w-50 exclusively. Car is 90% track only.
seanblurr is offline   Reply With Quote
Old 04-08-2019, 12:16 PM   #17
travislambert
travislambert's Avatar
Drives: '17 ZL1
Originally Posted by DANACO View Post
This is bad advise regarding “or even 11” you put the recommended amount in, run it, wait 15-20 minutes, check the level, period. Over filling can damage an engine, the specified amount is was not a guess by the engineers, it’s specific for many reasons.
Sure overfilling can damage an engine, but being over by 10% is not harmful. Show me one person who has blown their engine from running 11 quarts. I know of at least two cars that have blown their engine from oil starvation on the track with 10 quarts (and sticky tires).
Do I recommend purposely filling with 11 quarts? No, but my point is that it isn't going to matter if you do. Absolute precision isn't necessary. I don't know exactly what the threshold for a true overfill condition is, but I guarantee it's a lot higher than 11 quarts.
Personally, I use 10 quarts unless I'm on the track. In that case, I throw in a little extra because oil starvation in hard corners can and does happen on these wet sump systems. I track my car frequently, so at 6,000 miles I'm well over 30 oil changes. When I change the oil, I allow all of the oil to drain then add 10 quarts of Mobil 1 (using a portion to prefill the oil filter). There's no need to measure, start the engine, remeasure, etc.. It's all unnecessary.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 04-08-2019, 12:30 PM   #18
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I knew I read the owners manual right. There it is in print. Looks like the dealership filled the Ops ZL1 with the Liter measurement. You are right Travis. My view on the whole matter is, it isn’t rocket science!!
LT4Greg is offline   Reply With Quote
Old 04-08-2019, 01:19 PM   #19
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Blow Motors
Please tell me more about these blown LT4 motor Camaros. What tracks did this happen on, specific turns. What tires, Hoosiers or Pirelli DH?
Most importantly, how did Chevy respond with warranty support? Any issues with use of non-OEM tires?
Thanks!
SFV1LE is offline   Reply With Quote
Old 04-08-2019, 02:02 PM   #20
travislambert
Drives: '17 ZL1
Thanks!
I've only heard of this when non-OEM tires were used, so to my knowledge Chevy wasn't involved. I'm not aware of any problems with stock tires as I don't think there's enough grip to create a problem as long as you stay at 10 quarts.
I don't want to derail the thread, but here's two blown LT1s (same oil system as LT4) due to low oil pressure (references in posts 9 & 10). Talk to these guys for the details.
https://www.camaro6.com/forums/showthread.php?t=534469
2017 Camaro ZL1 M6
Old 04-08-2019, 02:20 PM   #21
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
I don't know how much wiggle room for overfilling there is on these engines, but "too much" oil can cause high crankcase pressures which can possibly affect seals, and oil foaming, which can affect a pump's ability to circulate enough oil. I base this statement not on LT* engine knowledge but on general engine knowledge.
Any idea what it is about the design that is causing starvation in corners, assuming that is real
This is that witty and clever statement that makes you chuckle.
Emoto is offline   Reply With Quote
Old 04-08-2019, 02:29 PM   #22
travislambert
Drives: '17 ZL1
It's a limitation of the wet sump system. That's one reason why higher-end cars have dry sump systems.
It's not a big problem because almost nobody drives hard enough to expose the problem. It's "real" though. Al even touches on it in his response here.
For the ZL1 1LE, 15W-50 is the required track oil due to the increased lateral acceleration capability of the vehicle. It has enough of a grip capacity increase above all the other models that the added protection from 15W-50 is needed. The thicker 50 weight viscosity helps with oil pan drawdown when the oil gets hot on the track and reduces risk of pressure dropouts. For the ZL1, 15w-50 will add protection but is not required, as the 0w-40 was tested and provides adequate protection in a track environment.
https://www.camaro6.com/forums/showt...php?p=10273387
When you upgrade to slicks, the 15W-50 might not be enough to save you. That's why a little extra oil is needed.
2017 Camaro ZL1 M6
Old 04-08-2019, 02:53 PM   #23
Emoto
Sure, why not?
Emoto's Avatar
Good info. Thanks!
Old 04-08-2019, 04:36 PM   #24
Vulcan1
Vulcan1's Avatar
Drives: 2018 Hyper Metallic Blue ZL-1 M6
Having many years experience with wet sump and dry sump systems in both drag and circle track racing here are a few points that are relevant to any generation engine. How much is to much?? When the crankshaft throws or Rods start slapping like a belly flop in the pool. On my Dyno I could measure solid HP gains by getting the oil away from the crankshaft by the use of windage trays, oil pump baffles and side sump pans. Think about it this way, oil is picked up and “ropes” around the rotating assembly. This is considerable drag, no different then pulling the prop of your boat motor out of the water and watching the tach spike up, no drag. I can reduce the oil level alone on the dyno just to the point that the oil level stabilizes above the pick up and see a solid 20-25 HP gain.
Now switch a wet sump engine over to a good dry sump system and I’m seeing 45-50 HP alone. Some of the big blocks with large strokes in the 598-632 CI displacements really stand out. Bottom line is a good balance between oil control from the rotating assembly and not uncovering the pickup tube. Oil pump cavitation from foam or no oil will destroy a pump in no time. PCV system in light tension ring packages is vastly important. As long as oil temperatures are controlled and the pickup is not uncovered no issues, street or track.
2018 ZL-1 Hyper-blue, Heads, Cam, Exhaust, Pulley, CAI, ported TB. 720HP/715TQ.
Vulcan1 is offline   Reply With Quote
Old 04-08-2019, 05:08 PM   #25
SFV1LE
I've heard firsthand from owners about 4 failures, 2 with a dry sump C6 corvette and 2 with an LS7 Z28 (also dry sump). The same Corvette and Z28 Camaro each failed twice. The common culprit in this was banked left turn 1-2 at Auto Club Speedway Roval, with cars traveling 130-150 MPH.
So this can happen to dry sump cars also, but I've only seen it happen with Chevy dry sump. I doubt a GT3 or 458/488 would have this problem.
Old 04-10-2019, 01:20 PM   #26
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
The manual says to add an extra quart for track days and to remove that when your track day is over. I keep 11 quarts in mine. No problems.
Pollock is offline   Reply With Quote
Old 04-10-2019, 01:48 PM   #27
SFV1LE
I believe that is only for the LT1 and not the LT4, I read it somewhere too but cant find it in the 2018 Camaro track prep guide or performance supplement.
Adding 1/2 quart wont hurt, but I'd prefer not to go 1 full qt over.
Old 04-10-2019, 05:35 PM   #28
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1
10 every time
swizlstik is offline   Reply With Quote
