Old 02-18-2018, 07:41 AM   #1
J1o6sh
Drives: 2013 Camaro SS
Exclamation Popping Metal noise on the rear
Quick question guys. Whenever I go over a deep bump, my car makes a noise on the bottom rear side. Sounds like a metal popping. No mods except for an MBRP axle back and a tune. Also, I Just started noticing it the other day. Had the axle back checked but everything is still tight and intact. There were a few scrapes tho.
J1o6sh is offline   Reply With Quote
Old 02-18-2018, 10:03 AM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Have you checked all the rear suspension?
Sent from my SM-G955U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-18-2018, 10:07 AM   #3
JOURDAN
Drives: 2010 Camaro SS 2SS
How many miles? It could be a drive shaft CVD - when you go over a large bump it move your suspension a large amount. This in turn changes the angle of your drive shaft, if it is worn out or damaged it could be binding and popping.
who knows though...
JOURDAN is offline   Reply With Quote
Old 02-18-2018, 11:05 AM   #4
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Um could you just be bottoming out due to the fact that you are going to fast over the bumps? What is a deep bump anyway? Do you mean a speed bump or a pothole?
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 02-18-2018, 02:33 PM   #5
J1o6sh
Exclamation
Originally Posted by dynosteve View Post
is the noise in the front or rear end?
Hi Sir. It’s is coming from the rear end.
Old 02-18-2018, 02:35 PM   #6
J1o6sh
Exclamation
who knows though...
Car has less than 12k miles.
Old 02-18-2018, 02:40 PM   #7
J1o6sh
Exclamation
Both speed bump/pot holes. It runs pretty good on a smooth surface.
Old 02-19-2018, 11:06 AM   #8
Stewart
Stewart's Avatar
Well the obvious solution would be is to slow down going over speed bumps and through pot holes.
Old 02-19-2018, 11:26 AM   #9
69 SS 350 5 Speed
69 SS 350 5 Speed's Avatar
Drives: 69 SS Camaro 2019 Corvette GS Vert.
Have your rear suspension knuckles checked. One of the bushings in the left rear knuckle was worn bad one my wife's 15 2SS and was clunking when I applied any, and I mean any torque. The car had 30,000 miles when I noticed it.
There is a fine line between hobby and obsession and I think I crossed it!!
69 SS 350 5 Speed is offline   Reply With Quote
Old 02-19-2018, 01:22 PM   #10
J1o6sh
Exclamation
Thanks. Yes it’s on the drivers rear side. You’re right, you can also hear the noise when any torque is applied.
Old 02-19-2018, 10:34 PM   #11
J1o6sh
Exclamation
Just got my car back and you were right. They told me the bushing was loose on the driver side. fortunately, it wasn’t worn out yet.
Old 02-20-2018, 07:25 AM   #12
69 SS 350 5 Speed
Good deal!! Glad you caught it early.
Old 03-20-2018, 09:22 PM   #13
J1o6sh
Alright guys the noise came back. Does this have anything to do with me tuning the car?
Old 03-21-2018, 01:17 AM   #14
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
A loose bushing will wear faster than a tight bushing.
When they said it "wasn't worn out" did they mean it was worn, but not enough to require a replacement?
And, being worn as a result of being loose (or the other way around) would indicate to me a replacement.
Ask them "how is the right side?" and if they say, "well, it's okay for now..." have them replace that as well. Be sure they replace the bolts and nuts and inspect the attachment points while it's apart.
Better to catch these issues early then wait until there is a failure.
2011 1SS/RS LS3 CGM
