dave@hennessey
Old 05-06-2016, 09:54 AM   #1
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 IBM L99
how will 1" lowering springs affect my 1/4 runs?
Just looking for some feedback / information in terms of suspension. I'm not really familiar with how it will affect it or what i should look for in suspension.
likely continue to do drag racing.
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M
11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M
10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M
10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D
Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS)
Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM
Mkn95u0 is offline   Reply With Quote
Old 05-06-2016, 10:00 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I installed Eibach Pro springs in my ZL1 and it made no difference in 60' times. I too thought it may negatively affect my dragstrip launch and weight transfer. Fortunately, this was not the case.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-06-2016, 10:08 AM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Guarantee they will affect your launch. The stock springs have always yielded better squat and 60' times than lowering springs. I lost .1 to .15
Old 05-06-2016, 01:10 PM   #4
Mkn95u0
Mkn95u0's Avatar
so lowering springs will negatively impact most 60' times & launches? Is it just recommended to keep the stock springs, or is there a better alternative?
Robert
Old 05-06-2016, 06:29 PM   #5
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
On a good drag radial with a 1" drop I went 1.46 10.05
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 05-06-2016, 06:36 PM   #6
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
1.25 drop, M6 1.56 60' No difference here.
BFASTNOTLAST is offline   Reply With Quote
Old 05-06-2016, 11:27 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Interesting convo.
I'd like to lower my car 1.0 front and rear.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 05-07-2016, 01:40 AM   #8
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
1in drop requires camber bolts so you have the most rubber on the ground during a launch.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 05-07-2016, 04:52 AM   #9
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
I've been running Eibach's pro kit for years and managed to cut a 1.60 60' on stock tires and NT05's. I can see it hurting with weight transfer due to the stiffness of the springs though. I never ran the car on stock suspension.
I will be upgrading to coilovers here in the next month or so to try to get more out of my car.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 05-07-2016, 05:27 AM   #10
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Never ran mine on the stock springs. Made over 170 passes with my lowering springs. Never once gave it a thought, as drag racing was not on my priority list of concerns for lowering my ride. Looks and handling were the factors for me.
rtcat600man is offline   Reply With Quote
Old 05-07-2016, 07:05 AM   #11
Merc
In The Circle
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM M6
I'm working with Jordan from JDP on my coiler settings for the new Ride Tech's and He want's almost full stiff in the rear and full loose in the front. Jordan say's with IRS you don't want the rear to squat. Custom spring rates as well 350 in the front and 550 in the rear, stock is 300/500.
Merc is offline   Reply With Quote
Old 05-07-2016, 07:11 AM   #12
Merc
In The Circle
Merc's Avatar
1"+ lowered 1.63 60's.
Old 05-07-2016, 07:39 AM   #13
BFASTNOTLAST
Drives: 2012 SS LS3
woTVz_bwoDY&fs=1">woTVz_bwoDY&fs=1" type="application/x-shockwave-flash" width="855" height="505">
1.56 and still leaving soft. I also play with spring rubbers to stiffen the rear even more. I'll put them in later today and take a picture for you guys. But the IRS definitely does not like squat. Squat means loosing time going forward...... To an extent..
Old 05-07-2016, 07:40 AM   #14
BFASTNOTLAST
Drives: 2012 SS LS3
https://youtu.be/woTVz_bwoDY
