01-15-2015, 09:37 AM | #1 |
Drives: Camaro Join Date: Nov 2014
New Hoosier 325/45R18 dot drag radial.
They're now available for purchase for $265 each + shipping.
Here's the specs: http://www.hoosiertire.com/pdfs/pbDOTDragRadial.pdf Last edited by JBT; 01-15-2015 at 11:32 PM. |
01-15-2015, 05:11 PM | #2 |
striker
nice another option for 18"s
01-15-2015, 07:58 PM | #3 |
Drives: none Join Date: Aug 2011
What do we need a 30" tall tire for?
01-15-2015, 11:25 PM | #4 |
01-17-2015, 03:18 AM | #5 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
A 29" 325\40R18 would be nice.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
01-18-2015, 09:20 AM | #6 |
Drives: 2006 Z06 Join Date: Oct 2010
Is a 30" tire going to fit on any of these cars? I know there is no way that is fitting a vette.
Nick
Corvette Z06 -1200ish rwhp |
01-28-2015, 11:36 AM | #7 |
Drives: 03 duramax 01impala 2010 2ssrs Join Date: Feb 2009
Mine actually measured 29" and they hook great, and they have about 5"s of side wall, I had them last summer on 600 hp, this spring i'll have them on 800hp - 1200hp
01-28-2015, 12:23 PM | #8 |
Drives: 2013 SS Join Date: May 2013
That's good for a truck project I have going on!
01-28-2015, 03:23 PM | #9 |
Might be good for someone who runs out of gear at the track and doesn't want to change the gear ratio again. Even then that's alot of rolling weight/resistance.
01-29-2015, 02:07 PM | #10 |
big horsepower= big tire, or you can spend all you money on a 15" conversion and then fill the wheel-well with great big 15" tires, got a problem hooking up? these will do the trick and yes I row the gears and yes I drag race, sorry but these tires work. what's with all the negativity? ... linehand7 2013 and 2014 Oahe speedway Street/Trophy champion... you want to win races? hook and go... nuff said...
01-29-2015, 02:12 PM | #11 |
if you go to a 325/40/18 you are missing the point you need more sidewall to get the bite and like I said before mine weren't 30" tall.
01-29-2015, 11:08 PM | #12 |
Drives: 2013 Camaro SS Coupe L99 Join Date: Feb 2013
01-30-2015, 10:04 AM | #13 |
this is why I've been a member since feb 2009 andonly have 135 posts, everybody bashing each other, all i'm saying is hoosier sent me a set of these tires for research and development and if you want an 18" tire ( 18" corvette rims are cheap) and you plan on using it at the track, these are awesome! two time track champion... linehand7
04-14-2016, 03:28 AM | #14 |
Here
